iPhone 17 Pro Max Top Speaker Replacement
    1. iPhone 17 Pro Max Top Speaker Replacement, Safety precautions: step 1, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Safety precautions: step 1, image 2 of 2
      • Let your iPhone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone.
      • Hold the power and either volume button and slide to power off your phone.
      Ask FixBot
    2. iPhone 17 Pro Max Top Speaker Replacement, Cracked glass preparation: step 2, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Cracked glass preparation: step 2, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Cracked glass preparation: step 2, image 3 of 3
      Tool used on this step:
      iFixit Safety Glasses
      $7.95
      Buy
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone is cracked, follow this step.
      • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
      • Make sure there's a single strip of tape (not overlapping) across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    3. iPhone 17 Pro Max Top Speaker Replacement, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Remove the pentalobe screws: step 3, image 2 of 2
      • Use a P2 pentalobe screwdriver to remove the two 7.5 mm‑long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 17 Pro Max Top Speaker Replacement, Mark your opening picks: step 4, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Mark your opening picks: step 4, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Mark your opening picks: step 4, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • Alternatively, you can tape a coin 3 mm from the tip of the pick.
      Ask FixBot
    2. iPhone 17 Pro Max Top Speaker Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's slightly too hot to touch.
      • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
      Ask FixBot
    3. iPhone 17 Pro Max Top Speaker Replacement, Apply a suction handle: step 6, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Apply a suction handle: step 6, image 2 of 2
      • Apply a suction handle to the bottom edge of the screen, as close to the edge as possible.
      Ask FixBot
    4. iPhone 17 Pro Max Top Speaker Replacement, Screen bezel information: step 7, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Screen bezel information: step 7, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Screen bezel information: step 7, image 3 of 3
      • During the next step, make sure you're inserting your pick in the correct location:
      • There's a plastic bezel on the underside of the screen that sits on the frame. Insert your pick here, making sure it's completely under the bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll separate the two, complicating the repair.
      Ask FixBot
    5. iPhone 17 Pro Max Top Speaker Replacement, Insert an opening pick: step 8, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Insert an opening pick: step 8, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Insert an opening pick: step 8, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
      • This may take significant force. If you're having trouble, reheat the screen and try again.
      • Insert the tip of an opening pick in the gap you just created.
      Ask FixBot
    6. iPhone 17 Pro Max Top Speaker Replacement, Screen information: step 9, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Screen information: step 9, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Screen information: step 9, image 3 of 3
      • Don't insert your pick more than 3 mm under the screen to avoid damaging the following components:
      • The screen and ambient light sensor cables are located near the volume and Action buttons.
      • There are delicate spring contacts around the perimeter of the phone.
      • The underside of the screen has thin, metal clips that go into corresponding slots on the frame.
      Ask FixBot
    7. iPhone 17 Pro Max Top Speaker Replacement, Separate the bottom edge adhesive: step 10, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Separate the bottom edge adhesive: step 10, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Separate the bottom edge adhesive: step 10, image 3 of 3
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the pick inserted under the bottom right corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    8. iPhone 17 Pro Max Top Speaker Replacement, Remove the suction handle: step 11, image 1 of 1
      • Pull the small nub on the suction cup to remove it from the screen.
      Ask FixBot
    9. iPhone 17 Pro Max Top Speaker Replacement, Heat the right edge: step 12, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Heat the right edge: step 12, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Heat the right edge: step 12, image 3 of 3
      • Use a hair dryer or heat gun to heat the right edge of the screen until it's slightly too hot to touch.
      Ask FixBot
    10. iPhone 17 Pro Max Top Speaker Replacement, Separate the right edge adhesive: step 13, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Separate the right edge adhesive: step 13, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Separate the right edge adhesive: step 13, image 3 of 3
      • Insert a second opening pick under the bottom right corner of the screen.
      • Slide the pick up the right edge to separate the adhesive and release the two clips.
      • You may need to pry the screen up slightly to release the clips
      • Leave the pick inserted under the top right corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    11. iPhone 17 Pro Max Top Speaker Replacement, Heat the top edge: step 14, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Heat the top edge: step 14, image 2 of 2
      • Use a hair dryer or heat gun to heat the top edge of the screen until it's slightly too hot to touch.
      Ask FixBot
    12. iPhone 17 Pro Max Top Speaker Replacement, Separate the top edge adhesive: step 15, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Separate the top edge adhesive: step 15, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Separate the top edge adhesive: step 15, image 3 of 3
      • Insert a third opening pick under the top right corner of the screen.
      • Slide the pick along the top edge and barely around the top left corner to separate the adhesive and release the two clips.
      • Don't slide the pick farther, or you may damage the ambient light sensor cable.
      • Leave the pick inserted under the top left corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    13. iPhone 17 Pro Max Top Speaker Replacement, Heat the left edge: step 16, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Heat the left edge: step 16, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Heat the left edge: step 16, image 3 of 3
      • Use a hair dryer or heat gun to heat the left edge of the screen until it's slightly too hot to touch.
      Ask FixBot
    14. iPhone 17 Pro Max Top Speaker Replacement, Separate the left edge adhesive: step 17, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Separate the left edge adhesive: step 17, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Separate the left edge adhesive: step 17, image 3 of 3
      • Insert a fourth opening pick under the bottom left corner of the screen.
      • Slide the pick up the left edge to separate the adhesive and release the clip, stopping just before the volume up button.
      • You may need to pry up the screen slightly to release the clip.
      • Don't slide the pick farther, or you may damage the screen cable.
      Ask FixBot
    15. iPhone 17 Pro Max Top Speaker Replacement, Prop up the screen: step 18, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Prop up the screen: step 18, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Prop up the screen: step 18, image 3 of 3
      • At this point, the screen should be completely detached from the frame. If it feels stuck, go back around the perimeter and separate any remaining adhesive or clips.
      • Lift the screen straight up and swing it over the left edge, propping it up against a sturdy box or stack of books so the cables aren't strained.
      • Alternatively, you can lay the screen down flat over the left side.
      Ask FixBot
    16. iPhone 17 Pro Max Top Speaker Replacement, Remove the cover screws: step 19, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Remove the cover screws: step 19, image 2 of 2
      FixMat
      $36.95
      Buy
      • Use a JIS 00 screwdriver to remove the two 1.2 mm‑long screws securing the battery and screen cable covers (one for each cover).
      • Small iFixit Phillips bits are designed to work with JIS screws. You can try Phillips screwdrivers from other manufacturers, but you risk stripping the screw.
      Ask FixBot
    17. iPhone 17 Pro Max Top Speaker Replacement, Remove the covers: step 20, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Remove the covers: step 20, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Remove the covers: step 20, image 3 of 3
      • Remove the two covers.
      Ask FixBot
    18. iPhone 17 Pro Max Top Speaker Replacement, Disconnect the battery: step 21, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Disconnect the battery: step 21, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    19. iPhone 17 Pro Max Top Speaker Replacement, Disconnect the screen: step 22, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Disconnect the screen: step 22, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Disconnect the screen: step 22, image 3 of 3
      • Use the tip of an opening pick or the point of a spudger to pry up and disconnect the screen and front sensors press connectors.
      Ask FixBot
    20. iPhone 17 Pro Max Top Speaker Replacement, Remove the screen: step 23, image 1 of 1
      • Remove the screen.
      Ask FixBot
    1. iPhone 17 Pro Max Top Speaker Replacement, Remove the battery screws: step 24, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Remove the battery screws: step 24, image 2 of 2
      • Use a Torx Plus 4IP screwdriver to remove the screws securing the battery tray:
      • One 7.5 mm‑long screw
      • One 5.9 mm‑long screw
      • One 3.5 mm‑long screw
      • One 2.4 mm‑long screw
      • Ten 3.7 mm‑long screws
      • One 3.7 mm‑long screw
      • iPhone models with a physical SIM card won't have this screw.
      Ask FixBot
    2. iPhone 17 Pro Max Top Speaker Replacement, Remove the battery: step 25, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Remove the battery: step 25, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Remove the battery: step 25, image 3 of 3
      • Use your finger to lift the top left corner of the battery tray and remove it.
      • Be careful not to smudge the front camera.
      Ask FixBot
    1. iPhone 17 Pro Max Top Speaker Replacement, Remove the top speaker: step 26, image 1 of 1
      • Use a JIS 00 screwdriver to remove the three screws securing the top speaker:
      • Two 2.4 mm‑long screws
      • One 2.1 mm‑long screw
      Ask FixBot
    2. iPhone 17 Pro Max Top Speaker Replacement: step 27, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement: step 27, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement: step 27, image 3 of 3
      • Use the point of a spudger to pry up and loosen the top speaker.
      • Remove the top speaker.
      Ask FixBot
    1. iPhone 17 Pro Max Top Speaker Replacement, Disassembly complete: step 28, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone.
      • Depending on your iPhone model, some reassembly photos may have minor visual discrepancies. The procedure, however, will be correct for your iPhone.
      Ask FixBot
    1. iPhone 17 Pro Max Top Speaker Replacement, Install the top speaker: step 29, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Install the top speaker: step 29, image 2 of 2
      • Align the top edge of the top speaker with the iPhone.
      • Lay the speaker in its recess.
      Ask FixBot
    2. iPhone 17 Pro Max Top Speaker Replacement: step 30, image 1 of 1
      • Use a JIS 00 screwdriver to install the three top speaker screws:
      Ask FixBot
    1. iPhone 17 Pro Max Top Speaker Replacement, Install the battery: step 31, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Install the battery: step 31, image 2 of 2
      • Lay the battery tray in place.
      • Make sure not to trap any cables underneath the tray.
      Ask FixBot
    2. iPhone 17 Pro Max Top Speaker Replacement, Install the battery tray screws: step 32, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Install the battery tray screws: step 32, image 2 of 2
      • Use a Torx Plus 4IP screwdriver to install the battery tray screws:
      Ask FixBot
    1. iPhone 17 Pro Max Top Speaker Replacement, Clean the frame: step 33, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Clean the frame: step 33, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Clean the frame: step 33, image 3 of 3
      Buy
      • Work around the fragile grounding clips as you clean the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
      • Use tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
      • Use a spudger to scrape the adhesive residue off the frame.
      • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
      Ask FixBot
    2. iPhone 17 Pro Max Top Speaker Replacement: step 34, image 1 of 1
      • Apply a few drops of high concentration (>90%) isopropyl alcohol to the adhesive residue.
      • Use a microfiber or lint-free cloth to wipe in one direction along the perimeter of the frame to clean the residue.
      • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
      Ask FixBot
    3. iPhone 17 Pro Max Top Speaker Replacement, Clean the screen: step 35, image 1 of 1
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • If you're reusing your screen, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
      Ask FixBot
    4. iPhone 17 Pro Max Top Speaker Replacement, Orient the replacement adhesive: step 36, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Orient the replacement adhesive: step 36, image 2 of 2
      • Without peeling any liners, lay the adhesive sheet over the frame to determine its proper orientation.
      • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
      Ask FixBot
    5. iPhone 17 Pro Max Top Speaker Replacement, Apply the replacement adhesive: step 37, image 1 of 1
      • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
      • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
      • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
      Ask FixBot
    6. iPhone 17 Pro Max Top Speaker Replacement: step 38, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement: step 38, image 2 of 2
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
      • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
      Ask FixBot
    7. iPhone 17 Pro Max Top Speaker Replacement: step 39, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement: step 39, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement: step 39, image 3 of 3
      • Continue peeling away the liner from the adhesive as you gently press the adhesive into place.
      • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
      • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
      • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
      • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
      Ask FixBot
    8. iPhone 17 Pro Max Top Speaker Replacement: step 40, image 1 of 1
      • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
      • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
      Ask FixBot
    9. iPhone 17 Pro Max Top Speaker Replacement: step 41, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement: step 41, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement: step 41, image 3 of 3
      • Use the pull tab to peel off the large front liner from the adhesive. The pull tab is often in a corner of the liner.
      • At this point, you'll still have liners covering the perimeter. Don't remove these liners yet—they prevent the adhesive from accidentally sticking while you reassemble your iPhone.
      Ask FixBot
    10. iPhone 17 Pro Max Top Speaker Replacement, Connect the screen: step 42, image 1 of 1
      • Set the iPhone screen next to the frame such that the screen cables can comfortably reach the logic board.
      Ask FixBot
    11. iPhone 17 Pro Max Top Speaker Replacement: step 43, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement: step 43, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement: step 43, image 3 of 3
      • Use your finger or the flat end of a spudger to press and connect the two screen connectors onto the logic board.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    12. iPhone 17 Pro Max Top Speaker Replacement, Connect the battery: step 44, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Connect the battery: step 44, image 2 of 2
      • Use your finger or the flat end of a spudger to press and connect the battery connector onto the logic board.
      Ask FixBot
    13. iPhone 17 Pro Max Top Speaker Replacement, Test your repair: step 45, image 1 of 1
      • This is a good point to test your repair before sealing up your iPhone:
      • Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
      • If your iPhone doesn't turn on, connect it to a power source and try again.
      Ask FixBot
    14. iPhone 17 Pro Max Top Speaker Replacement, Install the battery connector cover: step 46, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement, Install the battery connector cover: step 46, image 2 of 2
      • Tuck the top edge of the battery connector cover under the cutout lip.
      • Make sure both tabs are tucked under the lip.
      • Align the cover by its screw hole and lay it in place.
      Ask FixBot
    15. iPhone 17 Pro Max Top Speaker Replacement: step 47, image 1 of 1
      • Use a JIS 00 screwdriver to install the 1.2 mm‑long screw to secure the battery connector cover.
      Ask FixBot
    16. iPhone 17 Pro Max Top Speaker Replacement, Install the screen connector cover: step 48, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Install the screen connector cover: step 48, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Install the screen connector cover: step 48, image 3 of 3
      • Tuck the left edge of the screen connector cover under the cutout lip.
      Ask FixBot
    17. iPhone 17 Pro Max Top Speaker Replacement: step 49, image 1 of 1
      • Use a JIS 00 screwdriver to install the 1.2 mm‑long screw to secure the screen connector cover.
      Ask FixBot
    18. iPhone 17 Pro Max Top Speaker Replacement, Remove the final adhesive liners: step 50, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Remove the final adhesive liners: step 50, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Remove the final adhesive liners: step 50, image 3 of 3
      • With one hand hold the screen steady.
      • Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
      • Make sure nothing touches the exposed adhesive.
      • Check the internals for any stray liners and remove them. There should be no liners remaining.
      Ask FixBot
    19. iPhone 17 Pro Max Top Speaker Replacement, Install the screen: step 51, image 1 of 3 iPhone 17 Pro Max Top Speaker Replacement, Install the screen: step 51, image 2 of 3 iPhone 17 Pro Max Top Speaker Replacement, Install the screen: step 51, image 3 of 3
      • Lower the screen onto the frame, beginning with the top edge.
      • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
      • Make sure the screen edge isn't pinching any cables.
      • Press along the edges of the iPhone until the screen sits flush against the frame.
      Ask FixBot
    20. iPhone 17 Pro Max Top Speaker Replacement: step 52, image 1 of 2 iPhone 17 Pro Max Top Speaker Replacement: step 52, image 2 of 2
      • Firmly squeeze around the entire perimeter of the iPhone.
      Ask FixBot
    21. iPhone 17 Pro Max Top Speaker Replacement, Apply heat to the perimeter: step 53, image 1 of 1
      • Use a hair dryer, heat gun, or an iOpener to heat the screen perimeter until it's slightly too hot to touch.
      • The heat softens the adhesive and helps create a better bond.
      Ask FixBot
    1. iPhone 17 Pro Max Top Speaker Replacement, Install the pentalobe screws: step 54, image 1 of 1
      • Use a P2 pentalobe screwdriver to install the two 7.5 mm‑long screws on either side of the charging port.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Arthur Shi
346,306 Reputation
923 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 53
Past 30 Days: 330
All Time: 1,734
