Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you are having difficulties with Samsung POWERbot VR9000, try referring to the troubleshooting page.
Background and Information
The Samsung POWERbot VR9000 is a robot vacuum released by Samsung in 2015. This model can be differentiated from other Samsung robot vacuums by its amber-colored dustbin and copper-like inserts placed around the top-facing camera.
The Samsung POWERbot VR9000 is mounted with 5 front facing sensors, 3 underside cliff sensors, a camera, and a rear sensor window. It possesses point cleaning functionality and features Samsung's CycloneForce, Visonary Mapping, and Digital Inverter technologies. Compared to previous models, this vacuum has stronger suction, a wider 12 inch brush, and is less prone to clogging. It has dimensions of 15 in x 5.35 in x 14.25 in and weighs approximately 10 lbs.
Additional Information
Samsung POWERbot VR9000 Support Page
Video of Samsung POWERbot VR9000 Features
Teardown of Samsung POWERbot VR9000
Samsung POWERbot VR9000 Spec Sheet
Samsung POWERbot SR20H9050U and SR20H9030U Series User Manual
Samsung POWERbot SR20H905** and SR20H903** Series User Manual
Author
with
Kyle Chin
1,946 Reputation
4 Guides authored
Cal Poly, Team S15-G3, Banghart Spring 2017 Member of Cal Poly, Team S15-G3, Banghart Spring 2017
CPSU-BANGHART-S17S15G3
4 Members
84 Guides authored
Past 24 Hours: 11
Past 7 Days: 30
Past 30 Days: 103
All Time: 16,715
