Samsung POWERbot VR9000 Left Driving Wheel Replacement
    1. Samsung POWERbot VR9000 Left Driving Wheel Replacement, Top Chassis: step 1, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement, Top Chassis: step 1, image 2 of 2
      • Turn off the emergency switch located at the bottom right of the POWERbot.
      Ask FixBot
    2. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 2, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 2, image 2 of 2
      • Insert the plastic opening tool under the black cover, near the Samsung logo on the back of the device, and partially pry open.
      Ask FixBot
    3. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 3, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 3, image 2 of 2
      • Slide the plastic opening tool to the left, remaining under the black cover, until two left side pins have been detached. Then slide the plastic opening tool to the right until two right side pins have been detached.
      • Grab the two clips near the front of the black cover, on in front of each wheel. Pull the clips away from the wheels.
      Ask FixBot
    4. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 4, image 1 of 3 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 4, image 2 of 3 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 4, image 3 of 3
      • Remove the black cover.
      Ask FixBot
    5. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 5, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 5, image 2 of 2
      • Insert the plastic opening tool under copper-colored cover, under the words "CycloneForce," and pry open, applying a small rotation, until the two pins are released .
      • Grab the underside of the cover and lift upwards while pushing forward until the cover pops off.
      Ask FixBot
    6. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 6, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 6, image 2 of 2
      • Remove the three 6mm Phillips #1 screws in the holes near the back of the device.
      Ask FixBot
    7. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 7, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 7, image 2 of 2
      • Remove the 6mm Phillips #1 screw in the hole that was under the copper-colored vacuum cover.
      Ask FixBot
    8. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 8, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 8, image 2 of 2
      • Flip the device over and remove the 6mm Phillips #1 screw in front of the left (from this perspective, right) wheel.
      Ask FixBot
    9. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 9, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 9, image 2 of 2
      • Detach the wider circuit connector by pressing down gently on the left end of the clip and pulling the connector out.
      • Pull the connector out by the top and bottom of the white piece and not by the wires.
      Ask FixBot
    10. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 10, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 10, image 2 of 2
      • Remove the top chassis from the POWERbot by grabbing the wheel covers and lifting upwards.
      Ask FixBot
    1. Samsung POWERbot VR9000 Left Driving Wheel Replacement, Left Driving Wheel: step 11, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement, Left Driving Wheel: step 11, image 2 of 2
      • Remove the two 5mm Phillips #1 screws in the holes closest to the left wheel.
      Ask FixBot
    2. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 12, image 1 of 2 Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 12, image 2 of 2
      • Detach the top-most circuit connector on the left side by pressing down gently on the left end of the clip and pulling the connector out.
      Ask FixBot
    3. Samsung POWERbot VR9000 Left Driving Wheel Replacement: step 13, image 1 of 1
      • Remove the driving wheel assembly from the POWERbot by grabbing the wheel and lifting upwards.
      Ask FixBot
26 other people completed this guide.
Kyle Chin
1,946 Reputation
4 Guides authored
Cal Poly, Team S15-G3, Banghart Spring 2017 Member of Cal Poly, Team S15-G3, Banghart Spring 2017
CPSU-BANGHART-S17S15G3
4 Members
84 Guides authored
9 Guide Comments
Thanks for the info but can you tell me where I can get the wheel assembly as I think the motor has burned out. Thanks
Stephen Rawlings - Reply Share
Thank you so much :) … You helped me save all the money that I have spent on the Samsung Powerbot as I thought there is no way to fix it !
Can't Thank you enough Kyle ;)
shiraku gori - Reply Share
Thanks for your information, also I would like to find the spare parts of wheel assembly . Can you recommend me for seller and prices?
October 23, 2018
Narit pukkapan
Rubber Tree - Reply Share
Thank you for the usefull instructions. The problem was the wheel engine broken. I’ve been surprised that it was not brushless. Now I will try to fix it. Have a nice time
David - Reply Share
Thank you for your instructions. I open it up and clean the left wheel decoder by blowing air thru it. Put it back and it run as new. Thank you again.
Uyen Vo - Reply Share
Past 24 Hours: 9
Past 7 Days: 32
Past 30 Days: 73
All Time: 20,083
