Samsung POWERbot VR9000 Powerbrush Replacement
    1. Samsung POWERbot VR9000 Powerbrush Replacement, Powerbrush: step 1, image 1 of 2 Samsung POWERbot VR9000 Powerbrush Replacement, Powerbrush: step 1, image 2 of 2
      • Turn off the emergency switch located at the bottom right of the POWERbot.
      Ask FixBot
    2. Samsung POWERbot VR9000 Powerbrush Replacement: step 2, image 1 of 2 Samsung POWERbot VR9000 Powerbrush Replacement: step 2, image 2 of 2
      • Press the two yellow tabs immediately below the POWERbrush.
      Ask FixBot
    3. Samsung POWERbot VR9000 Powerbrush Replacement: step 3, image 1 of 2 Samsung POWERbot VR9000 Powerbrush Replacement: step 3, image 2 of 2
      • Lift the brush cover, indicated by the yellow strip located above the yellow tabs.
      Ask FixBot
    4. Samsung POWERbot VR9000 Powerbrush Replacement: step 4, image 1 of 2 Samsung POWERbot VR9000 Powerbrush Replacement: step 4, image 2 of 2
      • Remove the power brush starting with the unhinged right side of the brush.
      Ask FixBot
Harrison Fugate
102 Reputation
1 Guide authored
Cal Poly, Team S15-G3, Banghart Spring 2017 Member of Cal Poly, Team S15-G3, Banghart Spring 2017
CPSU-BANGHART-S17S15G3
4 Members
84 Guides authored
2 Guide Comments
The brush is wobbly in position. Is there an insert on the right side of the brush at the bearing. This position, the bearing look too small for the opening of the cover and the upper plastic.
Charlie nguyen - Reply Share
Did you lose the rubber cover/ washer that goes over the bearing? You can replace it from Samsung if you did.
hawkswhispertwh - Reply Share
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 31
All Time: 2,586
