Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Samsung Galaxy XCover line of smartphones are a line of phones designed to be used in more rugged workplace environments. These phones are produced by Samsung, a South Korean tech conglomerate based in Seoul, but with global influence in the tech industry. The Galaxy XCover Pro was released in January of 2020 and was designed with a more durable frame and protective shell intended for use in more rugged environments.
The device uses a Nano-SIM card and holds 64 GB of space, with 4 gigs of RAM. It also has a microSDXC slot accessed by the removeable back cover. The smartphone is MIL-STD-810G compliant, meaning it has met military grade standards for durability and environmental resistance.
As the first in the line of XCover Pro phones, the device houses an IPS LCD display with an Octa-core CPU, as well as a dual camera housing a 25 MP, f/1.7, 26mm (wide) lens and 8 MP, f/2.2, 123˚ (ultrawide), 1/4.0", 1.12µm lens.
Identification
The Samsung Galaxy Pro phone can be identified by the textured back cover that can be removed for easy access to the replaceable battery and microSDXC and SIM2 card slots. For another identifier, the red-lined "Push-to-Talk" button can be found on the left side (Screen facing you) of the smartphone. The model number can be found by removing the back cover and pulling out the battery of the smartphone, printed on a sticker in the battery bay.
Identified model numbers beginning with SM-G715F, SM-G715U, or SM-G715W.
Technical Specifications
  • Body
    • 159.9 x 76.7 x 10 mm (6.30 x 3.02 x .39 in)
    • 219 g (7.69 oz)
    • Nano-SIM
    • Nano-SIM + Nano-SIM
    • MIL-STD-810G compliant
  • Display
    • IPS LCD
    • 6.3 in, 97.4 square cm
    • Resolution: 1080 x 2340 pixels in a 19.5:9 ratio
    • Corning Gorilla Glass 5
  • Software
    • Android 10, can upgrade to Android 13, One UI 5
    • Exynos 9611 (10 nm)
    • CPU: Octa-core (4x2.3 GHz Cortex-A73 & 4x1.7 GHz Cortex-A53)
    • GPU: Mali-G72 MP3
    • microSDXC
    • 64 GB storage, 4GB RAM
  • Back Camera
    • Dual:
      • 25 MP, f/1.7, 26mm (wide), PDAF
      • 8 MP, f/2.2, 123˚ (ultrawide), 1/4.0", 1.12µm
    • Dual-LED flash, HDR, panorama
    • Video: 1080p@30fps
  • Front Camera
    • 13 MP, f/2.0, (wide), 1/3.1", 1.12µm
    • HDR
    • Video: 1080@30fps
  • Audio
    • Loudspeaker
    • 3.5mm headphone jack
  • Internet/Communication
    • Wi-Fi 802.11, dual-band, Wi-Fi Direct
    • Bluetooth: 5.0, A2DP, LE
    • GPS, GLONASS, GALILEO, BDS
    • NFC included
    • FM radio
    • USB Type-C 2.0
  • Sensors
    • Fingerprint, accelerometer, gyro, proximity, compass ANT+
  • Battery
    • Li-Po 4050 mAh, removable
    • 15w wired charging
Additional Information
Samsung Galaxy XCover Pro official product page
Frequently Asked Questions about the Samsung Galaxy XCover Pro
Samsung Galaxy XCover Pro Specifications
HotHardware Review: Samsung Galaxy XCover Pro
ChrisTownsend Review: Samsung Galaxy XCover Pro
Samsung Galaxy XCover Pro on Amazon
Samsung Galaxy XCover Pro Product Datasheet
Samsung Galaxy XCover Pro ESChat Push-to-Talk Solution Flyer
Samsung Rugged Device Product Portfolio Spec Sheet
Samsung Galaxy XCover Pro Orion Voice-First Solution Product Flyer
Samsung SM-G715FN/DS Felhasználói kézikönyv
Samsung Galaxy XCover Pro User Manual
Samsung SM-G715FN/DS คู่มือการใช้งาน
Samsung SM-G715FN and SM-G715FN/DS User Manual
Samsung SM-G715FN/DS Käyttöopas
Samsung SM-G715U1 Quick Start Guide
Samsung SM-G715U1 User Manual
Samsung Galaxy XCover Pro SM-G715FN/DS Manuale dell'utente
Samsung SM-G715FN / SM-G715FN/DS User Manual
Samsung SM-G715FN/DS Mode d'emploi
Samsung Galaxy XCover Pro Manual del usuario
Author
with
Max Kletskov
42,382 Reputation
16 Guides authored
Past 24 Hours: 9
Past 7 Days: 60
Past 30 Days: 264
All Time: 8,894
