Samsung Galaxy XCover Pro Battery Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
40
Past 30 Days:
212
All Time:
699
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This is a guide detailing the removal and replacement for the battery of the Samsung Galaxy XCover Pro, model number SM-6715U. The battery powers the device and allows for normal function on a day to day basis. To constitute the XCover Pro for battery replacement, you may be finding it impossible to turn on the device, or it may struggle to keep a charge for an extended period of time. Ensure that the symptoms are not the cause of something that doesn't have to be replaced, such as a faulty charger or the device overheating, see more explanation in this guide; Samsung Galaxy's Battery Draining fast. Be cautious, damaging a battery can cause it to swell up and explode if handled incorrectly. Before beginning, ensure the battery is not swollen by inspecting the shape of the back cover.
Parts
Tools
    1. Samsung Galaxy XCover Pro Battery Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy XCover Pro Battery Replacement, Battery: step 1, image 2 of 2
      • Wedge either a fingernail or opening tool into the notch and pull the back cover of the device off, revealing the battery bay.
      Ask FixBot
    2. Samsung Galaxy XCover Pro Battery Replacement: step 2, image 1 of 2 Samsung Galaxy XCover Pro Battery Replacement: step 2, image 2 of 2
      • Place an opening tool or finger in the gap at the bottom of the battery bay, and use leverage to remove the battery from the device.
      • When replacing the battery, ensure the metal grooves are connected to the metal prongs on the right side of the bay first, and then press the battery in, almost like a hinge connected at the top.
      Ask FixBot
1 Guide Comment
Wow, this is so helpful. Thanks so much!!!
Abdusamad Yusuf - Reply Share
Past 24 Hours: 6
Past 7 Days: 40
Past 30 Days: 212
All Time: 699
