Samsung Galaxy XCover Pro Rear Camera Replacement
    1. Samsung Galaxy XCover Pro Rear Camera Replacement, Screen: step 1, image 1 of 1
      • Using a heat gun, or a hair dryer on high, heat the screen, focusing on the edges around the screen to melt the glue holding the screen on.
      Ask FixBot
    2. Samsung Galaxy XCover Pro Rear Camera Replacement: step 2, image 1 of 1
      • After heating, insert picks around the barrier of the screen as wedges to help with pulling the screen off.
      • The screen will begin to pry off with the picks inserted; however, a suction cup can be used to assist in separating the screen from the casing.
      Ask FixBot
    3. Samsung Galaxy XCover Pro Rear Camera Replacement: step 3, image 1 of 2 Samsung Galaxy XCover Pro Rear Camera Replacement: step 3, image 2 of 2
      • Unclip the black tab covering the motherboard and screen ribbon cables.
      Ask FixBot
    4. Samsung Galaxy XCover Pro Rear Camera Replacement: step 4, image 1 of 2 Samsung Galaxy XCover Pro Rear Camera Replacement: step 4, image 2 of 2
      • Use a spudger or tweezers to pull the ribbon connecting the screen to the device, disconnecting it entirely.
      Ask FixBot
    1. Samsung Galaxy XCover Pro Rear Camera Replacement, Motherboard: step 5, image 1 of 2 Samsung Galaxy XCover Pro Rear Camera Replacement, Motherboard: step 5, image 2 of 2
      • Remove the ribbon cable connecting the charging port board (bottom) and the motherboard (top).
      Ask FixBot
    2. Samsung Galaxy XCover Pro Rear Camera Replacement: step 6, image 1 of 3 Samsung Galaxy XCover Pro Rear Camera Replacement: step 6, image 2 of 3 Samsung Galaxy XCover Pro Rear Camera Replacement: step 6, image 3 of 3
      • Remove the fourteen 4 mm screws holding down the backplate using a Phillips #000 screwdriver.
      • Use an opening tool to remove the backplate.
      Ask FixBot
    3. Samsung Galaxy XCover Pro Rear Camera Replacement: step 7, image 1 of 3 Samsung Galaxy XCover Pro Rear Camera Replacement: step 7, image 2 of 3 Samsung Galaxy XCover Pro Rear Camera Replacement: step 7, image 3 of 3
      • Using an opening tool, disconnect the red and blue wires from the motherboard.
      • Disconnect the headphone jack and side button ribbon cables that are both connected to the motherboard.
      Ask FixBot
    4. Samsung Galaxy XCover Pro Rear Camera Replacement: step 8, image 1 of 2 Samsung Galaxy XCover Pro Rear Camera Replacement: step 8, image 2 of 2
      • Remove the two 2.4 mm screws from the motherboard using a Phillips #000 screwdriver.
      • Remove the motherboard with an opening tool or your finger.
      Ask FixBot
    1. Samsung Galaxy XCover Pro Rear Camera Replacement, Rear Camera: step 9, image 1 of 2 Samsung Galaxy XCover Pro Rear Camera Replacement, Rear Camera: step 9, image 2 of 2
      • Remove all ribbon cables connecting the rear camera to the motherboard.
      • Push the camera out from the back side of the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 98
All Time: 339
