Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Note
If you have a Saeco coffee maker, also take a look at the guides for Philips and Gaggia machines. They are all made by the same manufacturer and have a very similar design. Some components are identical in many cases, such as the pump, drain valve, heater or motor.
The Saeco Minuto family is a series of fully automatic coffee machines. The technology is typical Saeco, the brewing unit (brewgroup) is smaller (same as XSmall), maintenance is the same as for the larger models though. The different models vary at the extras such as milk foam production units and displays.
Care and Maintenance
A fully automatic coffee machine is not without maintenance! With these models you can remove the brewing units very easily and rinse it under running water. It is important to descale and to replace the gaskets/seals regularly, as instructed in the user manuals. The mill stones (here made of ceramics) are reputed to be of low wear, but may still need replacing if the coffee is no longer satisfactory. These models are prone to clogging the coffee spout with coffee oils which needs to be checked at intervals.
Further Information
Manufacturers Page (German)
Saeco Minuto Type HD8760 Инструкция по эксплуатации
Saeco Minuto HD8761/18 Black Automatic Espresso Machine with Classic Milk Frother Product Sheet
Saeco Minuto HD8761 and HD8764 Instructions for Use
Saeco Minuto HD8772 User Manual
Saeco HD8775 User Manual
Saeco Minuto HD8662 and HD8665 User Manual
Saeco Minuto HD8760 — Bedienungsanleitung
Saeco Minuto HD8760 — mode d'emploi
Saeco Minuto Type HD8762 Bedienungsanleitung
Saeco Minuto HD8761 / HD8764 Quick Instruction Guide
Saeco Minuto HD8760 Bedienungsanleitung
Saeco Minuto HD8661/HD8664 Bedienungsanleitung
Saeco Minuto HD8763 Bedienungsanleitung
Saeco Minuto Type HD8662, HD8665 Quick Instruction Guide (EN, IT, DE, FR, ES, PT)
Saeco Minuto Espresso Machine Quick Instruction Guide
Saeco Minuto HD8762 Instructions for Use
Saeco Minuto HD8760 Instructions for Use
Saeco Minuto Type HD8763 Instructions for Use
Saeco Milk Circuit Cleaning Powder Instructions for Espresso Machines (EN, IT, FR, NL, DE, PL)
Saeco Minuto HD8765/47 Black Espresso Machine with Classic Milk Frother Product Sheet
Philips Saeco Minuto Carafe HD8773/47 Quick Start Guide
Saeco Minuto HD8773/47 Silver Espresso Machine with Milk Carafe Product Brochure
Saeco Minuto HD8773 Operating Instructions
Saeco Minuto HD8775/48 Black Super-Automatic Espresso Machine Specifications
Saeco Minuto HD8772/47 Silver Espresso Machine with Automatic Milk Frother Specifications
Saeco Minuto Automatic Espresso Machine with Removable Brewing Group Brochure
Saeco Minuto HD8661/01 Essence Black Espresso Machine with Classic Milk Frother Product Sheet
Saeco Minuto HD8761/26 Black Espresso Machine with Classic Milk Frother Product Information
Saeco Minuto HD8762/07 Black Automatic Milk Frother Espresso Machine Product Sheet
Saeco Minuto Coffee Machine Service Manual
Saeco Minuto HD8761–HD8764 — Istruzioni per l'uso
Saeco Minuto HD8762 — Istruzioni per l'uso
Saeco Minuto HD8760 Istruzioni per l'uso
Philips Saeco Intenza+ Water Filter Cartridge Product Information
Special thanks to these translators:
de en
100%
+2
and 2 others...
These translators are helping us fix the world! Want to contribute?
Start translating ›
Past 24 Hours: 14
Past 7 Days: 68
Past 30 Days: 290
All Time: 16,273
