Up to 20% off select tools
Open a Saeco Minuto
Views: 82K
View statistics:
Past 24 Hours:
6
Past 7 Days:
83
Past 30 Days:
517
All Time:
82,170
Comments: 78
51 comments on steps, 27 guide comments.
Go to guide comments
Completed: 43
43 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Open a Saeco Minuto
Tools
Introduction
Go to step 1 ↓
This guide shows how to open a Saeco Minuto coffee machine. There are a lot of different versions of this coffee machine, also under the Philips brand. The pictures show a Philips HD 8834.
These instructions may also help with other Saeco models and with coffee makers from Philips and Gaggia—they are all made by the same manufacturer and have a very similar design.
    1. Open a Saeco Minuto, opening procedure: step 1, image 1 of 1
      • Disconnect the power plug!
      • Remove the water tank.
      • Remove all the coffee beans.
      • Remove the brewing assembly.
      • Remove the drip tray and the coffee grounds drawer.
      Ask FixBot
    2. Open a Saeco Minuto: step 2, image 1 of 3 Open a Saeco Minuto: step 2, image 2 of 3 Open a Saeco Minuto: step 2, image 3 of 3
      • Pry up with a plastic opening tool at the bottom edge of the chrome-plated cover to lift up the coffee dispensing spout. This cover is often very tight, so you have to pry hard and hope that the part does not break.
      • When the lower edge of the spout is released, you can pry on the side edge until the chrome cover comes off completely.
      Ask FixBot
    3. Open a Saeco Minuto: step 3, image 1 of 2 Open a Saeco Minuto: step 3, image 2 of 2
      • Remove the Torx T10 screw at the top edge of the coffee dispensing spout.
      Ask FixBot
    4. Open a Saeco Minuto: step 4, image 1 of 2 Open a Saeco Minuto: step 4, image 2 of 2
      • Lift off the black cover over the coffee dispensing spout. The sliding nozzles will come off at the same time.
      Ask FixBot
    5. Open a Saeco Minuto: step 5, image 1 of 1
      • Remove both Torx T10 screws on the left and right at the bottom edge of the coffee dispensing spout.
      • Pull off the hot water dispensing spout.
      Ask FixBot
    6. Open a Saeco Minuto: step 6, image 1 of 2 Open a Saeco Minuto: step 6, image 2 of 2
      • Remove the Torx T20 screw on the finger guard of the grinder. Remove the finger guard.
      • If the screws are covered with coffee remains, you should first clean them with a needle and a vacuum cleaner.
      • Remove three Torx T10 screws in the bean container.
      Ask FixBot
    7. Open a Saeco Minuto: step 7, image 1 of 1
      • Remove the three Torx T10 screws under the water tank.
      Ask FixBot
    8. Open a Saeco Minuto: step 8, image 1 of 3 Open a Saeco Minuto: step 8, image 2 of 3 Open a Saeco Minuto: step 8, image 3 of 3
      • Grab the upper cover on the sides and lift it up.
      • The cover is still connected with a cable and a tube.
      • Take off the silicone tube.
      Ask FixBot
    9. Open a Saeco Minuto: step 9, image 1 of 1
      • Remove the water level sensor cable from its brackets.
      • Carefully remove the plug from the water level sensor.
      • The cover is now free and can be removed.
      Ask FixBot
Repeat the steps in reverse order to reassemble your device.
43 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
349,691 Reputation
325 Guides authored
27 Guide Comments
Hallo, habe versucht das bei HD8844 zu machen. Allerdings gibt es hier am Kaffeeauslauf den zusätzlichen Hebel (Espresso/Cafe). Der lässt sich via 2 seitlicher Torx entfernen, aber letztlich lässt sich Schritt 4 nicht durchführen. Selbst bei entfernten Schrauben scheint die Hebelhalterung zu blockieren und niemand (es haben mehrer Personen probiert), schafft es die schwarze Abdeckung des Kaffeeauslaufs zu enfernen um die beiden Torx für Schritt 5 erreichen zu können. Irgendwelche Ideen?
s.ruso - Reply Share
Kenne dieses Modell leider nicht. Hier ein kleiner Hinweis.
VauWeh - Reply Share
Und hier viele Bilder. Hoffentlich hilft es.
Leider kann man mit dieser Anleitung nur die Haube entfernen. An einer Entfernung der seitlichen Abdeckung bin ich gescheitert, das Ding scheint aus einem Guss zu sein, ich kann die Pumpe von der Seite nicht freilegen. Saeco Minuto HD8761
Matzewol - Reply Share
Hmm. Kann mich gar nicht mehr richtig erinnern, ich meine das ginge ganz leicht?! Ich muss sowieso demnächst wieder eine zerlegen, vielleicht kann ich die Beschreibung fortsetzen.
Past 24 Hours: 6
Past 7 Days: 83
Past 30 Days: 517
All Time: 82,170
