Up to 20% off select tools
Saeco Minuto Test Mode
Views: 13K
View statistics:
Past 24 Hours:
7
Past 7 Days:
44
Past 30 Days:
273
All Time:
13,270
Comments: 2
2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The Minuto can be put into test mode very easily. It allows you to easily check many functions.
These instructions may also help with other Saeco models and with coffee makers from Philips and Gaggiaβ€”they are all made by the same manufacturer and have a very similar design.
    1. Saeco Minuto Test Mode, Saeco Minuto Test Mode: step 1, image 1 of 3 Saeco Minuto Test Mode, Saeco Minuto Test Mode: step 1, image 2 of 3 Saeco Minuto Test Mode, Saeco Minuto Test Mode: step 1, image 3 of 3
      • Turn off the machine at the power switch on the back.
      • With your left hand, press and hold the top left and bottom right buttons at the same time. On this model, it is the espresso and menu buttons.
      • Turn the power switch on the back back on with your other hand. Release the buttons and the machine is in test mode
      Ask FixBot
    2. Saeco Minuto Test Mode: step 2, image 1 of 2 Saeco Minuto Test Mode: step 2, image 2 of 2
      • The first screen shows the technical data and the software version.
      • To get to the next screen, tap the power button on the front.
      Ask FixBot
    3. Saeco Minuto Test Mode: step 3, image 1 of 2 Saeco Minuto Test Mode: step 3, image 2 of 2
      • In the next menu you can test the keys. Press one of the keys, then the display should turn red and the corresponding key should appear.
      • In the second picture the espresso button is pressed.
      Ask FixBot
    4. Saeco Minuto Test Mode: step 4, image 1 of 1
      • The sensors are displayed in the third menu. H20 stands for water tank, DOOR for the door sensor, BU-P indicates the brew group sensor. N means no, of course, Y means yes.
      Ask FixBot
    5. Saeco Minuto Test Mode: step 5, image 1 of 1
      • In the next menu you can test the brew group motor and the sensors for the end position. WORK is the upper end position, HOME is the rest position. CUR outputs the position of the drive shaft.
      • To move the engine, briefly tap the top left or middle button.
      Ask FixBot
    6. Saeco Minuto Test Mode: step 6, image 1 of 1
      • The next screen is split. The electric valve can be seen on the left, closed here. Press the top left button to shift. On the right the pump or the impulses of the flowmeter. To test, press the top right button.
      Ask FixBot
    7. Saeco Minuto Test Mode: step 7, image 1 of 1
      • The next screen is split again. On the left is the temperature of the heater, if you press the top left button, the heater will turn on and the temperature will increase. On the right you can check the grinder by pressing the top right button, key figures for the motor are displayed.
      • The next key press takes you back to the beginning. To exit test mode, turn the device off and on again using the power switch on the back.
      Ask FixBot
Work the steps in reverse order to reassemble your device.
5 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
349,359 Reputation
324 Guides authored
2 Guide Comments
Bin sehr dankbar fΓΌr diese Anleitung πŸ‘πŸ‘πŸ‘ŒπŸ‘Œ
Kaffeemann - Reply Share
meine Philips HD8829 hat leider kein Display ...
Leopold Gann - Reply Share
Past 24 Hours: 7
Past 7 Days: 44
Past 30 Days: 273
All Time: 13,270
