Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Olympus Tough TG-3 is a compact 16-megapixel waterproof digital camera that features a maximum resolution of 4608 x 3456. This model features a microscope mode that allows the user to take pictures as close as 10mm away from the subject and magnify up to 13.8x with Super Resolution Zoom.
Identification
The Olympus Tough TG-3 differs from its predecessor, the TG-2, because it has built-in Wi-Fi connectivity. You can also identify this camera by checking the top left corner above the screen for the model label "STYLUS TG-3".
Specifications
Body type: Compact
Max resolution: 4608 x 3456
Effective pixels: 16 megapixels
Sensor size: 1/2.3" (6.17 x 4.55 mm)
Sensor type: BSI-CMOS
ISO: Auto, 100-6400
Focal length (equiv.): 25–100 mm
Max. aperture: F2–4.9
Articulated LCD: Fixed
Screen size: 3″
Screen dots: 460,000
Max shutter speed: 1/2000 sec
Format: H.264, Motion JPEG
Storage types: SD, SDHC, SDXC, Internal Memory
USB: USB 2.0 (480 Mbit/sec)
Weight (Including batteries): 247 g (0.54 lb / 8.71 oz)
Dimensions: 112 x 66 x 31 mm (4.41 x 2.6 x 1.22″)
GPS: Built-in
Overview
Additional Information
Olympus TG-3 Digital Camera Instruction Manual
Olympus PT-056 Underwater Case for TOUGH TG-3 System Chart
Olympus TG-3 Cámara digital: Manual de instrucciones
Olympus STYLUS TG-3 – Compact tout-terrain : fiche technique
Olympus TG-3 — Manuel d'instructions
Olympus TG-3 デジタルカメラ 取扱説明書
Olympus TG-3 Digitalkamera Bedienungsanleitung
Olympus TG-3 Câmara Digital — Manual de Instruções
Olympus TG-3 Fotocamera digitale — Manuale d'uso
Author
with
Natalia Morales
675 Reputation
5 Guides authored
USF Tampa, Team 1-6, Leahy Fall 2016 Member of USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
3 Members
60 Guides authored
Past 24 Hours: 4
Past 7 Days: 34
Past 30 Days: 123
All Time: 11,266
