Introduction
This guide will show you how to replace the shutter and ON/OFF buttons on the Olympus Tough TG-3 digital camera. You’ll be removing the front casing and internal button housing, so handle all tools and parts with care.
Caution:
- This procedure involves handling small screws and sharp metal components. Work slowly and carefully.
- To avoid losing screws, secure them to masking tape in order as you remove them.
- Make sure your hands are clean and dry before touching any internal components.
Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
Locate the strap eyelet side of the camera.
Use a PH000 screwdriver to remove the two 5.3 mm screws that secure the strap mount to the front case.
Set the screws aside safely, they’ll be needed for reassembly.
1 Guide Comment
Thanks for the post. Do you know where to buy new switches?
