Olympus Digital Camera TG-3 Lens Ring Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
95
All Time:
3,163
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide requires you to handle sharp metal objects. Proceed with caution. To avoid misplacing the screws hold them in place with masking tape. Make sure your hands are clean and dry before they come in contact with the internal parts of the camera.
Tools
    1. Olympus Digital Camera TG-3 Lens Ring  Replacement, Front Case: step 1, image 1 of 1
      • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
      Ask FixBot
    2. Olympus Digital Camera TG-3 Lens Ring  Replacement: step 2, image 1 of 1
      • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
      Ask FixBot
    3. Olympus Digital Camera TG-3 Lens Ring  Replacement: step 3, image 1 of 1
      • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
      Ask FixBot
    4. Olympus Digital Camera TG-3 Lens Ring  Replacement: step 4, image 1 of 1
      • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
      Ask FixBot
    5. Olympus Digital Camera TG-3 Lens Ring  Replacement: step 5, image 1 of 1
      • Now you should be able to remove the front case easily using your hand.
      Ask FixBot
    1. Olympus Digital Camera TG-3 Lens Ring  Replacement, Lens Ring: step 6, image 1 of 1
      • Twist the ring around the camera lens and pull it out.
      Ask FixBot
Natalia Morales
675 Reputation
5 Guides authored
USF Tampa, Team 1-6, Leahy Fall 2016 Member of USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 95
All Time: 3,163
