Up to 20% off select tools
Olympus Digital Camera TG-3 Shutter Button Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
124
All Time:
4,853
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide requires you to handle sharp metal objects. Proceed with caution. To avoid misplacing the screws hold them in place with masking tape. Make sure your hands are clean and dry before they come in contact with the internal parts of the camera.
    1. Olympus Digital Camera TG-3 Shutter Button  Replacement, Front Case: step 1, image 1 of 1
      • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
      Ask FixBot
    2. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 2, image 1 of 1
      • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
      Ask FixBot
    3. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 3, image 1 of 1
      • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
      Ask FixBot
    4. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 4, image 1 of 1
      • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
      Ask FixBot
    5. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 5, image 1 of 1
      • Now you should be able to remove the front case easily using your hand.
      Ask FixBot
    1. Olympus Digital Camera TG-3 Shutter Button  Replacement, Back Case: step 6, image 1 of 1
      • Using the PH000 screwdriver, remove the two 4mm screws located on the left side of the camera, under the strap holder.
      Ask FixBot
    2. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 7, image 1 of 1
      • Use a PH000 screwdriver to remove the 3 mm screw located on the bottom of the battery compartment.
      Ask FixBot
    3. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 8, image 1 of 1
      • Hold the device as shown in the picture. Using the PH000 screwdriver, remove the 9mm screw located on the upper left side of the camera.
      Ask FixBot
    4. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 9, image 1 of 1
      • Use the PH000 screwdriver to remove the 7mm screw you'll find toward the lower left side of the camera.
      Ask FixBot
    5. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 10, image 1 of 1
      • Use a PH000 screwdriver to remove the 6mm screw on the upper right side of the camera, above the flash.
      Ask FixBot
    6. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 11, image 1 of 1
      • Using the PH000 screwdriver, remove the 1.2 mm located on the lower right side of the device, towards the corner.
      Ask FixBot
    7. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 12, image 1 of 1
      • Use the PH0000 screwdriver to remove the 7 mm located on the upper side of the camera, where the shutter and zoom bottoms are. You will find the screw towards the middle of this section.
      Ask FixBot
    8. Olympus Digital Camera TG-3 Shutter Button  Replacement: step 13, image 1 of 1
      • Remove the back case using your hand.
      Ask FixBot
4 other people completed this guide.
Author
with
Natalia Morales
675 Reputation
5 Guides authored
USF Tampa, Team 1-6, Leahy Fall 2016 Member of USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
3 Members
60 Guides authored
2 Guide Comments
Bravo super tutorial, but how to ensure the sealing after disassembly and reassembly?
vincent vidal - Reply Share
I have a problem recovering the original condition. Is it possible Someone help me to restore it. Olympus TG-3 contact back. Witrocker@hotmail.com
Dawis rocker - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 124
All Time: 4,853
