Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
Diagnose your problem at the Merch Source Projector Entertainment II troubleshooting page.
Background
The Merch Source Projector Entertainment II allows you to watch TV, DVDs, video games and even stream movies and videos from your laptop. This projector can produce an image up to 7.5 feet wide (diagonally) onto any smooth, white surface.
If your projector isn’t working correctly, don't worry, you are not alone. The most common point of failure is the light bulb. According to online reviews, they burn out quickly or can even shatter. This projector has also been known to overheat and shut off randomly during use. There is little information on this projector provided by Merch Source. As of right now, there is a “new website coming soon”.
Identification
There is a built in stereo, cooling fan and an adjustable focus lens. A slightly different model of this projector comes in black, but the two are not exactly the same. The Merch Source Entertainment II projector is white, with a white and green handle, as well as a green ring along the outside of the lens casing.
Additional Information
Official Instruction Manual
Additional General Resources
Author
with
Winthrop Townsend
287 Reputation
1 Guide authored
Cal Poly, Team 18-3, Maness Winter 2015 Member of Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Members
48 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 41
All Time: 31,856
