Up to 20% off select tools
Merch Source Projector Entertainment II Motherboard
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
91
All Time:
2,708
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes - 1 hour
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
Follow this guide to repair components on the logic board. All you will need a solder gun and steady hands.
    1. Merch Source Projector Entertainment II Motherboard, Outer Casing: step 1, image 1 of 2 Merch Source Projector Entertainment II Motherboard, Outer Casing: step 1, image 2 of 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Ask FixBot
    2. Merch Source Projector Entertainment II Motherboard: step 2, image 1 of 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Ask FixBot
    3. Merch Source Projector Entertainment II Motherboard: step 3, image 1 of 2 Merch Source Projector Entertainment II Motherboard: step 3, image 2 of 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Ask FixBot
    1. Merch Source Projector Entertainment II Motherboard, Motherboard: step 4, image 1 of 2 Merch Source Projector Entertainment II Motherboard, Motherboard: step 4, image 2 of 2
      • Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
      • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
      • Once the housing is disengaged, the ribbon cable should slide out easy. Do not pull too hard on the ribbon cable as it is very fragile.
      Ask FixBot
    2. Merch Source Projector Entertainment II Motherboard: step 5, image 1 of 2 Merch Source Projector Entertainment II Motherboard: step 5, image 2 of 2
      • Unscrew the three 6 mm screws from the motherboard with the Phillips #0 screwdriver.
      • Be sure not to damage any of the wires atached to the motherboard.
      Ask FixBot
    3. Merch Source Projector Entertainment II Motherboard: step 6, image 1 of 2 Merch Source Projector Entertainment II Motherboard: step 6, image 2 of 2
      • Solder off all of the connections on the motherboard with a soldering iron.
      • Once connections are soldered off, the motherboard should be detached and ready for replacement.
      • Need some help? Follow this guide to learn soldering basics.
      • While soldering the metal connections can get very hot. Never touch the iron with your hand. also make sure that the projector is fully turned off and not plugged in.
      • If there is hot glue on top on the connection with the motherboard, you will need to peel it off using your fingers.
      Ask FixBot
Author
with
Michael Tan
590 Reputation
3 Guides authored
3 Guide Comments
Was wondering if you could help me identify a microchip on the board by the speaker?
Brad Langland - Reply Share
Where can I get parts for the projector? I think my board is cooked.
Delgtm - Reply Share
mine acts like it does not recognize the rca cords. help
Kamela Mitchell - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 91
All Time: 2,708
