Merch Source Projector Entertainment II Cooling Fan Replacement
Views: 3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
20
Past 30 Days:
111
All Time:
3,009
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes - 1 hour
Difficulty: Difficult
Introduction
Go to step 1 ↓
Is your projector overheating? Is it powering down at random times? Use this guide to replace the malfunctioning fan. Replacing the fan requires a fine tip soldering iron and should be done by those with solder experience.
Tools
    1. Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: step 1, image 1 of 2 Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: step 1, image 2 of 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Ask FixBot
    2. Merch Source Projector Entertainment II Cooling Fan Replacement: step 2, image 1 of 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Ask FixBot
    3. Merch Source Projector Entertainment II Cooling Fan Replacement: step 3, image 1 of 2 Merch Source Projector Entertainment II Cooling Fan Replacement: step 3, image 2 of 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Ask FixBot
    1. Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: step 4, image 1 of 2 Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: step 4, image 2 of 2
      • Locate the 80 mm fan and slide upward straight out of the housing.
      Ask FixBot
    2. Merch Source Projector Entertainment II Cooling Fan Replacement: step 5, image 1 of 2 Merch Source Projector Entertainment II Cooling Fan Replacement: step 5, image 2 of 2
      • Unsolder the red and black connections off of the motherboard.
      • If there are zip ties around the cables, they will need to be cut to remove the fan.
      • Need some help? Follow this guide to learn soldering basics.
      • While soldering the metal connections will get very hot. Never touch the iron with your hand.
      • Make sure that the projector is fully turned off and not plugged in. Allow up to 30 minutes for projector to cool down.
      • If there is hot glue within the connection in on the motherboard, you will need to peel it off simply using your fingers.
      Ask FixBot
Stephanie
282 Reputation
3 Guides authored
Cal Poly, Team 18-3, Maness Winter 2015 Member of Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 111
All Time: 3,009
