Up to 20% off select tools
Merch Source Projector Entertainment II Light Bulb Replacement
Views: 3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
110
All Time:
3,018
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Tools
Introduction
Go to step 1 ↓
Dim picture? No display? Discolored output? No problem! Use this guide to replace the burnt light bulb with a new one. To complete this replacement, you will need the following parts ready:
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: step 1, image 1 of 2 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: step 1, image 2 of 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Ask FixBot
    2. Merch Source Projector Entertainment II Light Bulb Replacement: step 2, image 1 of 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Ask FixBot
    3. Merch Source Projector Entertainment II Light Bulb Replacement: step 3, image 1 of 2 Merch Source Projector Entertainment II Light Bulb Replacement: step 3, image 2 of 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Ask FixBot
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: step 4, image 1 of 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: step 4, image 2 of 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: step 4, image 3 of 3
      • Remove the light bulb from its housing unit.
      • Do not damage the 2 white cables leading into the light bulb panel.
      Ask FixBot
    2. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: step 5, image 1 of 2 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: step 5, image 2 of 2
      • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
      • The light blub is held into the socket with prongs, and should easily pull straight out.
      Ask FixBot
Author
with
Stephanie
282 Reputation
3 Guides authored
Cal Poly, Team 18-3, Maness Winter 2015 Member of Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Members
48 Guides authored
1 Guide Comment
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 110
All Time: 3,018
