Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Released in July of 2016, it has a textured black backing and a 5.7 inch screen. Beneath its standard appearance is a removable battery with an average talk time of 22 hours; reliable stylus functionality; and features (such as hearing aid capabilities) that are relatively uncommon on other mid-range devices.
Power button and volume controls can be found on the back of the device, right below the 13-megapixel camera. The LG Stylo 2 Plus is capable of video recording in 1920x1080 (Full HD)(30fps) and 1280x720 (HD) (30fps). The stylus is located on the top right-hand side of the device, and when pulled out will activate a number of note-related apps on-screen. LG Stylo 2 Plus also boasts hearing aid connectivity via Bluetooth. Despite the discontinued status of the phone, its wide range of features and relative affordability results in a solid, reliable substitute for current, more expensive models.
Identification
The LG Stylo 2 Plus can be identified by its model number: MS550.
Troubleshooting
If you are having difficulties with the LG Stylo 2 Plus, try referring to the troubleshooting page.
Additional Information
LG Stylo 2 Plus Specs
LG Stylo 2 Plus Master Reset
LG Stylo 2 Plus Manual
Unlock the LG Stylo 2 Plus
Buy on Amazon
Author
with
Tiffany Wheeler
308 Reputation
2 Guides authored
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Members
84 Guides authored
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 34
All Time: 2,120
