Up to 20% off select tools
LG Stylo 2 Plus Battery Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
54
All Time:
1,365
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Very easy
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If your LG Stylo 2 Plus is experiencing problems charging, not holding a charge for long, or will no longer turn on it might be time to replace is battery. Battery replacement on this device is a simple task, but you need to remember to gentle; the back is made of plastic and can break.
    1. LG Stylo 2 Plus Battery Replacement, Rear Case: step 1, image 1 of 3 LG Stylo 2 Plus Battery Replacement, Rear Case: step 1, image 2 of 3 LG Stylo 2 Plus Battery Replacement, Rear Case: step 1, image 3 of 3
      • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
      • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
      Ask FixBot
    1. LG Stylo 2 Plus Battery Replacement, Battery: step 2, image 1 of 3 LG Stylo 2 Plus Battery Replacement, Battery: step 2, image 2 of 3 LG Stylo 2 Plus Battery Replacement, Battery: step 2, image 3 of 3
      • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
      • Firmly grasp the battery and remove from the phone.
      Ask FixBot
Please dispose of the old battery properly by bringing it to a electronics recycling facility or calling the phone number on the back for more instructions.
Author
with
Noah Kehm
241 Reputation
3 Guides authored
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 54
All Time: 1,365
