Up to 20% off select tools
LG Stylo 2 Plus Mid-Frame Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
52
All Time:
559
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will assist you in the removal process of the LG Stylo 2 Plus mid-frame.
    1. LG Stylo 2 Plus Mid-Frame Replacement, Rear Case: step 1, image 1 of 3 LG Stylo 2 Plus Mid-Frame Replacement, Rear Case: step 1, image 2 of 3 LG Stylo 2 Plus Mid-Frame Replacement, Rear Case: step 1, image 3 of 3
      • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
      • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
      Ask FixBot
    1. LG Stylo 2 Plus Mid-Frame Replacement, Battery: step 2, image 1 of 3 LG Stylo 2 Plus Mid-Frame Replacement, Battery: step 2, image 2 of 3 LG Stylo 2 Plus Mid-Frame Replacement, Battery: step 2, image 3 of 3
      • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
      • Firmly grasp the battery and remove from the phone.
      Ask FixBot
    1. LG Stylo 2 Plus Mid-Frame Replacement, Mid-Frame: step 3, image 1 of 2 LG Stylo 2 Plus Mid-Frame Replacement, Mid-Frame: step 3, image 2 of 2
      • Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
      Ask FixBot
    2. LG Stylo 2 Plus Mid-Frame Replacement: step 4, image 1 of 2 LG Stylo 2 Plus Mid-Frame Replacement: step 4, image 2 of 2
      • Insert the metal spudger in the dimple at the base of the cover.
      • Pry upward, removing the mid-frame from the phone.
      Ask FixBot
Author
with
Tiffany Wheeler
308 Reputation
2 Guides authored
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 52
All Time: 559
