Up to 20% off select tools
LG Stylo 2 Plus Front Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
44
All Time:
735
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
If you need to replace the front facing camera of your LG Stylo 2 Plus, follow this guide. When the phone is unable to capture photographs due to damage a replacement will be necessary. This an intermediate task that will involve handling small, delicate parts of the device (e.g. ribbon cable).
    1. LG Stylo 2 Plus Front Camera Replacement, Rear Case: step 1, image 1 of 3 LG Stylo 2 Plus Front Camera Replacement, Rear Case: step 1, image 2 of 3 LG Stylo 2 Plus Front Camera Replacement, Rear Case: step 1, image 3 of 3
      • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
      • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
      Ask FixBot
    1. LG Stylo 2 Plus Front Camera Replacement, Battery: step 2, image 1 of 3 LG Stylo 2 Plus Front Camera Replacement, Battery: step 2, image 2 of 3 LG Stylo 2 Plus Front Camera Replacement, Battery: step 2, image 3 of 3
      • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
      • Firmly grasp the battery and remove from the phone.
      Ask FixBot
    1. LG Stylo 2 Plus Front Camera Replacement, Mid-Frame: step 3, image 1 of 2 LG Stylo 2 Plus Front Camera Replacement, Mid-Frame: step 3, image 2 of 2
      • Using the JIS #000 screwdriver, remove the eleven 4mm screws around the mid-frame.
      Ask FixBot
    2. LG Stylo 2 Plus Front Camera Replacement: step 4, image 1 of 2 LG Stylo 2 Plus Front Camera Replacement: step 4, image 2 of 2
      • Insert the metal spudger in the dimple at the base of the cover.
      • Pry upward, removing the mid-frame from the phone.
      Ask FixBot
    1. LG Stylo 2 Plus Front Camera Replacement, Front Camera: step 5, image 1 of 3 LG Stylo 2 Plus Front Camera Replacement, Front Camera: step 5, image 2 of 3 LG Stylo 2 Plus Front Camera Replacement, Front Camera: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Using a pair of tweezers, carefully detach the ribbon cable connecting the camera to the motherboard.
      • Still using the tweezers, firmly pull up to remove the camera from the phone.
      Ask FixBot
Author
with
Joshua Sisson
73 Reputation
1 Guide authored
UW Tacoma, Team S1-G3, Cardinal Spring 2019 Member of UW Tacoma, Team S1-G3, Cardinal Spring 2019
UWT-CARDINAL-S19S1G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 44
All Time: 735
