Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
Diagnose, fix problems and find parts using the HTC Touch Pro 2 Toubleshooting Guide
Background
The HTC Touch Pro 2 smartphone features a slide-out (QWERTY) keyboard and a 3.6-inch touch-sensitive screen. If your HTC smartphone turns on then it will display its model type across the screen while it starts up.
Some things that set the HTC Touch Pro 2 apart from the original Touch Pro are: the Touch Pro 2 has a larger screen size as well as phone size in general, it has a tougher less glossy outer case, a slide out keyboard that pivots to angle the screen, and the Touch Pro 2's camera does not have a flash built into it.
Highlights of the device are:
  • a slide-out-5-row keyboard with well-spaced keys
  • 3.6-inch touch-sensitive screen with WWGA (480 X 800 pixel) resolution
  • dual microphone/speaker providing crystal-clear conference call capability
  • adjustable tilt screen for enhanced viewing experience
  • zoom bar to precisely zoom in or out when viewing images or web pages
Identification
Identified by model number: Touch Pro 2.
Additional Information
Buy used on Amazon
HTC products
HTC Touch Pro2 User Manual
Sprint HTC Touch Pro2 User Guide
Author
with
Melinda Phan
438 Reputation
9 Guides authored
Cal Poly, Team 9-64, Walters Spring 2011 Member of Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Members
108 Guides authored
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 60
All Time: 17,090
