Up to 20% off select tools
HTC Touch Pro 2 Battery Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
111
All Time:
5,123
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the battery in your HTC Touch Pro 2 is not charging correctly, losing power quickly, or is damaged then it is time for a replacement. This guide would replace the battery for the HTC Touch Pro 2 to work at an improved pace.
    1. HTC Touch Pro 2 Battery Replacement, Battery: step 1, image 1 of 3 HTC Touch Pro 2 Battery Replacement, Battery: step 1, image 2 of 3 HTC Touch Pro 2 Battery Replacement, Battery: step 1, image 3 of 3
      • Apply pressure and slide upward to remove back cover.
      • Lift the back cover up away from the phone.
      Ask FixBot
    2. HTC Touch Pro 2 Battery Replacement: step 2, image 1 of 2 HTC Touch Pro 2 Battery Replacement: step 2, image 2 of 2
      • Lift battery upward on the upper right-hand side to remove it.
      • Check the battery to make sure there's no bent corners.
      Ask FixBot
Author
with
Melinda Phan
438 Reputation
9 Guides authored
Cal Poly, Team 9-64, Walters Spring 2011 Member of Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 111
All Time: 5,123
