Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
HP first introduced the Pavilion zd8000 in 2004 and discontinued the model in 2008. The most common problem is a screen display malfunction. This malfunction involves lines appearing across the screen with roughly half of the screen going black. Another common problem is overheating.
Identification
You can find the model of your laptop next to the speakers below the screen's HP logo. It should read "HP Pavilion zd80XX", where XX can be anywhere from 00 to 80.
Specifications
Color display: 17" LCD ViewBright display, 1440 x 900 resolution
Processor: Intel Pentium 4 540 (3.2 GHz, 1MB L2 Cache)
RAM: 512MB DDR2 SDRAM
Battery: Lithium ion 6.6 Ah
Hard drive: Toshiba 80 GB (5400 rpm)
Weight: 9.3 lbs
Additional Information
Author
with
Tyson Mobley
271 Reputation
0 Guides authored
Cal Poly, Team 24-56, Amido Spring 2011 Member of Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Members
156 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 63
All Time: 38,857
