HP Pavilion zd8000 Keyboard Replacement
    1. HP Pavilion zd8000 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Slide the battery release latch towards you.
      Ask FixBot
    2. HP Pavilion zd8000 Keyboard Replacement: step 2, image 1 of 2 HP Pavilion zd8000 Keyboard Replacement: step 2, image 2 of 2
      • Pull up on the battery to remove it.
      Ask FixBot
    1. HP Pavilion zd8000 Keyboard Replacement, Keyboard: step 3, image 1 of 1
      • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
      Ask FixBot
    2. HP Pavilion zd8000 Keyboard Replacement: step 4, image 1 of 2 HP Pavilion zd8000 Keyboard Replacement: step 4, image 2 of 2
      • Flip the laptop over and open the screen.
      • Push up on the four latches located at the top of the keyboard with the spudger to release them.
      Ask FixBot
    3. HP Pavilion zd8000 Keyboard Replacement: step 5, image 1 of 2 HP Pavilion zd8000 Keyboard Replacement: step 5, image 2 of 2
      • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
      • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
      Ask FixBot
    4. HP Pavilion zd8000 Keyboard Replacement: step 6, image 1 of 2 HP Pavilion zd8000 Keyboard Replacement: step 6, image 2 of 2
      • Rotate the keyboard so that the bottom is visible.
      • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
      • Pull the tab towards you to release the keyboard from the laptop.
      Ask FixBot
Allie Menard
820 Reputation
13 Guides authored
Cal Poly, Team 24-56, Amido Spring 2011 Member of Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 126
All Time: 4,765
