HP Pavilion zd8000 Left Speaker Replacement
    1. HP Pavilion zd8000 Left Speaker Replacement, Battery: step 1, image 1 of 1
      • Slide the battery release latch towards you.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 2, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 2, image 2 of 2
      • Pull up on the battery to remove it.
      Ask FixBot
    1. HP Pavilion zd8000 Left Speaker Replacement, RAM: step 3, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement, RAM: step 3, image 2 of 2
      • Loosen the Phillips screw labeled ‘ram’ and lift the cover.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 4, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 4, image 2 of 2
      • Locate the green RAM card and find the metal tabs securing the card.
      • Push outwards on the two tabs to release the card.
      Ask FixBot
    3. HP Pavilion zd8000 Left Speaker Replacement: step 5, image 1 of 1
      • Carefully slide the card out at an upward angle away from the slot.
      Ask FixBot
    1. HP Pavilion zd8000 Left Speaker Replacement, WiFi Card Cables: step 6, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement, WiFi Card Cables: step 6, image 2 of 2
      • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
      • Lift the cover from the right to remove it.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 7, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to detach the grey and black cables connected to the green WiFi card.
      Ask FixBot
    1. HP Pavilion zd8000 Left Speaker Replacement, CD/Optical Drive: step 8, image 1 of 1
      • Remove the 8mm Philips screw located between the hard drive and the WiFi card.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 9, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 9, image 2 of 2
      • Turn the laptop 90 degrees clockwise so you are facing the CD drive.
      • Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
      Ask FixBot
    3. HP Pavilion zd8000 Left Speaker Replacement: step 10, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 10, image 2 of 2
      • Gently pull the tray away from the laptop and the rest of the optical drive will follow.
      Ask FixBot
    1. HP Pavilion zd8000 Left Speaker Replacement, Keyboard: step 11, image 1 of 1
      • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 12, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 12, image 2 of 2
      • Flip the laptop over and open the screen.
      • Push up on the four latches located at the top of the keyboard with the spudger to release them.
      Ask FixBot
    3. HP Pavilion zd8000 Left Speaker Replacement: step 13, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 13, image 2 of 2
      • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
      • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
      Ask FixBot
    4. HP Pavilion zd8000 Left Speaker Replacement: step 14, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 14, image 2 of 2
      • Rotate the keyboard so that the bottom is visible.
      • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
      • Pull the tab towards you to release the keyboard from the laptop.
      Ask FixBot
    1. HP Pavilion zd8000 Left Speaker Replacement, Switch Cover: step 15, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement, Switch Cover: step 15, image 2 of 2
      • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
      • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 16, image 1 of 1
      • Flip the laptop over.
      • Fully open the laptop.
      Ask FixBot
    3. HP Pavilion zd8000 Left Speaker Replacement: step 17, image 1 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 17, image 2 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 17, image 3 of 3
      • Rotate it so the display is on your right and the keyboard is on your left.
      • Lift the switch cover firmly but slowly so you do not snap it.
      • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
      • The switch cover should easily separate from the laptop as you run the spudger through.
      Ask FixBot
    1. HP Pavilion zd8000 Left Speaker Replacement, Screen: step 18, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement, Screen: step 18, image 2 of 2
      • Close the lid and rotate the laptop so that the vents are facing you.
      • Unscrew the two 8mm Philips screws below the hinges.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 19, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 19, image 2 of 2
      • Carefully rotate the laptop 90 degrees counter-clockwise and open the screen.
      • Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
      Ask FixBot
    3. HP Pavilion zd8000 Left Speaker Replacement: step 20, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 20, image 2 of 2
      Buy
      • Using tweezers, remove the black cable from the hole leading to the WiFi enclosure.
      • Pull gently to remove the black and grey cables from the case.
      • Check the surface beneath the laptop to ensure the cables do not catch on anything when you flip the laptop over.
      Ask FixBot
    4. HP Pavilion zd8000 Left Speaker Replacement: step 21, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 21, image 2 of 2
      • Using tweezers, pull the black cable towards the display and through the hole in the casing.
      Ask FixBot
    5. HP Pavilion zd8000 Left Speaker Replacement: step 22, image 1 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 22, image 2 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 22, image 3 of 3
      • Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display.
      • Lift the screen upwards to detach it from the laptop.
      Ask FixBot
    1. HP Pavilion zd8000 Left Speaker Replacement, Top Cover: step 23, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement, Top Cover: step 23, image 2 of 2
      • With the laptop face-down, remove the eleven 8mm Philips screws.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 24, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 24, image 2 of 2
      • Rotate the laptop 180 degrees so the vents are facing you.
      • Unscrew the four 3mm Philips screws below the vents.
      Ask FixBot
    3. HP Pavilion zd8000 Left Speaker Replacement: step 25, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 25, image 2 of 2
      • Rotate the laptop 90 degrees counter-clockwise.
      • Unscrew the two 3mm Philips screws from the optical drive bay.
      Ask FixBot
    4. HP Pavilion zd8000 Left Speaker Replacement: step 26, image 1 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 26, image 2 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 26, image 3 of 3
      • Flip the laptop over so it is face-up with the trackpad closest to you.
      • Locate the ribbon cable directly above the track pad.
      • Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
      Ask FixBot
    5. HP Pavilion zd8000 Left Speaker Replacement: step 27, image 1 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 27, image 2 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 27, image 3 of 3
      • Find the ribbon cable on the LED board located at the top of the laptop.
      • You will notice that the ribbon cable is connected to two levels - you will be dealing with the one on the lower level.
      Ask FixBot
    6. HP Pavilion zd8000 Left Speaker Replacement: step 28, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 28, image 2 of 2
      Buy
      • Locate the white connector attached to a red and black cable to the right of the LED board.
      • Using tweezers, pull the white connector away from you.
      Ask FixBot
    7. HP Pavilion zd8000 Left Speaker Replacement: step 29, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 29, image 2 of 2
      • Unscrew the four 8mm Philips screws from the top cover.
      Ask FixBot
    8. HP Pavilion zd8000 Left Speaker Replacement: step 30, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 30, image 2 of 2
      • Rotate the computer 90 degrees clockwise and insert the spudger at the seam above the card reader.
      • While lifting the front end of the top cover, slide the spudger across the seam.
      • When you have reached the firewire port, it should click open.
      Ask FixBot
    9. HP Pavilion zd8000 Left Speaker Replacement: step 31, image 1 of 1
      • Lift the top cover from the left side to remove it completely.
      Ask FixBot
    1. HP Pavilion zd8000 Left Speaker Replacement, USB Module: step 32, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement, USB Module: step 32, image 2 of 2
      • Locate the USB Module
      • Grip the yellow cable cover and pull it to the right to release it.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 33, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 33, image 2 of 2
      • Unscrew the 6mm Philips screw connecting the USB module to the fan.
      Ask FixBot
    3. HP Pavilion zd8000 Left Speaker Replacement: step 34, image 1 of 1
      • Pull the module to the right and lift it out to release it.
      Ask FixBot
    1. HP Pavilion zd8000 Left Speaker Replacement, Motherboard: step 35, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement, Motherboard: step 35, image 2 of 2
      • Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 36, image 1 of 1
      • Unscrew and remove the two 8mm Philips screws from the heat sink fan.
      Ask FixBot
    3. HP Pavilion zd8000 Left Speaker Replacement: step 37, image 1 of 1
      Buy
      • Using tweezers, remove the digital drive board cable - the cable set on the right with black, red, green, and white wires.
      • Using tweezers, remove the the rigth speaker cable - the cable set on the left with red and black wires - by pulling the white connector towards you.
      Ask FixBot
    4. HP Pavilion zd8000 Left Speaker Replacement: step 38, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 38, image 2 of 2
      • Using tweezers, remove the left speaker cable by pulling the white connector towards you.
      Ask FixBot
    5. HP Pavilion zd8000 Left Speaker Replacement: step 39, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 39, image 2 of 2
      • Remove the LED board cable by pulling the white tab towards you.
      Ask FixBot
    6. HP Pavilion zd8000 Left Speaker Replacement: step 40, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 40, image 2 of 2
      • Remove the audio cable - the one with the yellow covering located at the bottom-right corner of the motherboard - by pulling the yellow covering towards you.
      Ask FixBot
    7. HP Pavilion zd8000 Left Speaker Replacement: step 41, image 1 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 41, image 2 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 41, image 3 of 3
      • Rotate the laptop 180 degrees and locate the Bluetooth module at the bottom-left corner of the motherboard.
      • Using tweezers, remove the Bluetooth module’s white connector by pulling it away from you.
      Ask FixBot
    8. HP Pavilion zd8000 Left Speaker Replacement: step 42, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 42, image 2 of 2
      • Using tweezers, pull up on the Bluetooth module to remove it.
      Ask FixBot
    9. HP Pavilion zd8000 Left Speaker Replacement: step 43, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 43, image 2 of 2
      • Remove the fan cable by pulling the white connector away from you.
      Ask FixBot
    10. HP Pavilion zd8000 Left Speaker Replacement: step 44, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 44, image 2 of 2
      • Using pliers, unscrew and remove the two bolts from both sides of the blue VGA connector.
      Ask FixBot
    11. HP Pavilion zd8000 Left Speaker Replacement: step 45, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 45, image 2 of 2
      • Carefully flip the laptop face-down with the battery compartment facing you.
      • Using tweezers, remove the black and red cable from the RAM compartment by pulling on the white connector.
      Ask FixBot
    12. HP Pavilion zd8000 Left Speaker Replacement: step 46, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 46, image 2 of 2
      • Flip the laptop face-up and turn it so that the drive labelled "hp usb digital drive" faces you.
      • Press the ridged space saver card above the "hp usb digital drive" label to eject and remove it.
      Ask FixBot
    13. HP Pavilion zd8000 Left Speaker Replacement: step 47, image 1 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 47, image 2 of 3 HP Pavilion zd8000 Left Speaker Replacement: step 47, image 3 of 3
      • Locate the PC card below the SD card reader.
      • Push the button to its left once to eject the button itself, then press it once again to remove the PC card.
      Ask FixBot
    14. HP Pavilion zd8000 Left Speaker Replacement: step 48, image 1 of 1
      • Once the PC card pops out, pull it out.
      Ask FixBot
    15. HP Pavilion zd8000 Left Speaker Replacement: step 49, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 49, image 2 of 2
      • Turn the computer 90 degrees counter-clockwise and clear all cables off of the motherboard.
      • Push in the grey button to the left of the PC card as far as possible.
      • Keeping the button pressed down, lift the motherboard up until the button pops out the top of the case.
      Ask FixBot
    16. HP Pavilion zd8000 Left Speaker Replacement: step 50, image 1 of 1
      • Pull the right casing to the side to release the ports on the motherboard from it.
      Ask FixBot
    17. HP Pavilion zd8000 Left Speaker Replacement: step 51, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 51, image 2 of 2
      • Lift the motherboard up until it releases from the bottom casing and remove it from the laptop.
      Ask FixBot
    1. HP Pavilion zd8000 Left Speaker Replacement, Left Speaker: step 52, image 1 of 3 HP Pavilion zd8000 Left Speaker Replacement, Left Speaker: step 52, image 2 of 3 HP Pavilion zd8000 Left Speaker Replacement, Left Speaker: step 52, image 3 of 3
      • Pull the USB cable away from the speaker.
      Ask FixBot
    2. HP Pavilion zd8000 Left Speaker Replacement: step 53, image 1 of 1
      • Unscrew the 6mm Philips screw at the back of the left speaker unit.
      Ask FixBot
    3. HP Pavilion zd8000 Left Speaker Replacement: step 54, image 1 of 2 HP Pavilion zd8000 Left Speaker Replacement: step 54, image 2 of 2
      • Lift the speaker unit up, flip it, and remove the USB cable.
      Ask FixBot
    4. HP Pavilion zd8000 Left Speaker Replacement: step 55, image 1 of 1
      • Cut the tape that attaches the USB cable to the left speaker cable.
      Ask FixBot
2 other people completed this guide.
Allie Menard
820 Reputation
13 Guides authored
Cal Poly, Team 24-56, Amido Spring 2011 Member of Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Members
147 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 34
All Time: 11,561
