Removing HP Pavilion zd8000 WiFi Card Cables
    1. Removing HP Pavilion zd8000 WiFi Card Cables, Battery: step 1, image 1 of 1
      • Slide the battery release latch towards you.
      Ask FixBot
    2. Removing HP Pavilion zd8000 WiFi Card Cables: step 2, image 1 of 2 Removing HP Pavilion zd8000 WiFi Card Cables: step 2, image 2 of 2
      • Pull up on the battery to remove it.
      Ask FixBot
    1. Removing HP Pavilion zd8000 WiFi Card Cables, WiFi Card Cables: step 3, image 1 of 2 Removing HP Pavilion zd8000 WiFi Card Cables, WiFi Card Cables: step 3, image 2 of 2
      • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
      • Lift the cover from the right to remove it.
      Ask FixBot
    2. Removing HP Pavilion zd8000 WiFi Card Cables: step 4, image 1 of 2 Removing HP Pavilion zd8000 WiFi Card Cables: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to detach the grey and black cables connected to the green WiFi card.
      Ask FixBot
Allie Menard
820 Reputation
13 Guides authored
Cal Poly, Team 24-56, Amido Spring 2011 Member of Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Members
147 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 3,735
