Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The HP Pavilion TouchSmart 11z-e000 is part of the HP Pavilion TouchSmart 11 series, released in 2013.
It comes with an AMD A4-1250 dual-core 1.0GHz APU with integrated HD 8210 graphics. It has an 11.6" 1366x768 touchscreen display. It contains a 320GB hard drive.
Identification
Although the laptop is mostly plastic, it has a brushed aluminum finish on the lid and chassis. It is lightweight and weighs about 3.4 lbs. Look on the bottom of the laptop to find the product name, model, and serial number of your device.
Specifications
Operating System
The HP Pavilion TouchSmart 11z-e000 can run all versions of Windows 7, Vista, and XP.
Memory
The HP Pavilion TouchSmart 11z-e000 uses 4GB of DDR3 memory, operating at a 1333 MHz frequency. You can upgrade the memory to up to 8GB for better multitasking.
Graphics Card
The HP Pavilion TouchSmart 11z-e000 comes with integrated AMD H8210 graphics that cannot be removed as it is built into the processor.
Hard Drive
The HP Pavilion TouchSmart 11z-e000 comes with a 5400 rpm 320GB hard drive. This can be replaced or upgraded for much more room for files and programs.
Additional Information
HP Pavillion Touchsmart 11 Maintenance and Service Guide
User Guide
HP Support Page for HP Pavillion Touchsmart 11
HP 210/215 G1 and Pavilion 11/TouchSmart 11 Notebook PCs Maintenance and Service Guide
Author
with
Robert Hemphill
278 Reputation
2 Guides authored
Cal Poly, Team 21-22, Maness Winter 2015 Member of Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Members
72 Guides authored
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 64
All Time: 10,058
