HP Pavilion Touchsmart 11z-e000 Fan Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
30
Past 30 Days:
97
All Time:
1,561
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
The fan is a key component to the laptop in that it draws cool air into the laptop and expels hot air. A functioning fan helps the computer perform well by preventing components in the laptop from overheating.
Tools
    1. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Battery: step 1, image 1 of 1
      • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
      Ask FixBot
    1. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Fan: step 2, image 1 of 1
      • Slide a spudger under the outer plastic cover of the laptop.
      • Pry the outer plastic cover off of the laptop, one side at a time.
      • Prying the outer plastic cover off may take a significant amount of force.
      Ask FixBot
    2. HP Pavilion Touchsmart 11z-e000 Fan Replacement: step 3, image 1 of 1
      • Unscrew all screws attaching the fan to the metal backboard.
      Ask FixBot
    3. HP Pavilion Touchsmart 11z-e000 Fan Replacement: step 4, image 1 of 1
      • Turn the laptop over.
      • Slide a spudger in between the outer plastic cover of the keyboard and the main body of the laptop.
      • Pry the top plastic cover off of the laptop.
      • Prying the outer plastic cover off may take a significant amount of force. Be careful!
      Ask FixBot
    4. HP Pavilion Touchsmart 11z-e000 Fan Replacement: step 5, image 1 of 1
      • Unscrew the two screws that keep the fan in place.
      Ask FixBot
    5. HP Pavilion Touchsmart 11z-e000 Fan Replacement: step 6, image 1 of 1
      • Unplug the fan from the circuit board as shown
      • Carefully peel the tape connecting the fan and pull out the fan from the laptop.
      Ask FixBot
Nguyen
301 Reputation
2 Guides authored
Cal Poly, Team 21-22, Maness Winter 2015 Member of Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 97
All Time: 1,561
