Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer runs very slowly
Tasks such as surfing the web, opening a program, or turning on the laptop take longer than they should.
The laptop's default hardware may not be sufficient for your needs and uses
This laptop is not very expensive, and as a result it's processing power is not very competitive. Consider replacing this laptop's default memory with a more powerful option. Refer to the memory module replacement guide for this device.
Laptop is overheating.
The laptop is hot to the touch.
The laptop's fans may not be working properly.
If you cannot hear the fan running, even when the device feels extremely hot to touch, replace the fan.
The laptop may have dust stuck in its fan vents
If the fan is running, but the laptop still feels hot, clean the fan by opening up the device and dusting the blades of the fan. Refer to the Fan Replacement guide for this device.
The touch screen does not work properly
The screen does not turn on, or when trying to use the touch screen feature of the laptop, it does not respond to input.
A software update may have caused this
When updating to Windows 8, certain settings have to be modified in order to ensure that the touch screen works properly. Resources can be found online.
The touch screen itself could be damaged
If the touchscreen is completely unresponsive even though the mousepad works and you have tried the steps above, replace the touch screen.
Keyboard or keys are not responsive
The keys may be stuck or jammed.
If you cannot press down on the keyboard, the keyboard may have something under it. Clean the keyboard by either taking a cotton swab under it or opening up the device and getting to the keyboard.
Keys or keyboard may be broken.
Since you cannot fix a single key, unless the problem lies in the plastic key itself, you should replace the keyboard. Refer to the keyboard replacement guide for this device.
I can't download any more stuff
When trying to download additional programs or files, the laptop says that there is no free space on its hard drive.
The laptop's hard-drive may be full
Consider uninstalling unwanted programs or files already stored on the laptop's hard drive. Otherwise, consider upgrading the laptop's hard drive.
Trouble connecting to Wifi and other wireless networks
The laptop struggles to connect to available wifi, or does not recognize wifi at all.
The WLAN card may be malfunctioning
If other devices are not having problems connecting to the same wifi, replace the WLAN card. Refer to the WLAN card replacement guide for this device.
Derrick Ho
288 Reputation
1 Guide authored
Cal Poly, Team 21-22, Maness Winter 2015 Member of Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 31
All Time: 994
