Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
Address any problems you may be having with your Google Home using our Google Home Troubleshooting Page.
Background and Identification
Announced at the October 4th, 2015 #madebygoogle event and released November 4th, 2016, the Google Home is a voice activated, smart home speaker with built in Google Assistant. It is the first smart speaker from Google (to compete with the Amazon Echo), the first generation coming before the Home Mini and Home Max.
This speaker comes in white with seven interchangeable base colors, from black to gray, gold metallic to bright purple. The Model is Home and the serial number is located on the bottom of the device.
The Google Home is compatible with music services such as Google Play, Spotify, Youtube, and Pandora. Beyond music, it can communicate with Google ChromeCast, Google Nest Thermostat, and the Phillips Hue Smart Bulb system. The Personal Assistant is supported by Google search technology, allowing it to answer questions and improve and customize search results over time.
Technical Specifications
Dimensions:
  • Diameter: 3.79 in (96.4 mm)
  • Height: 5.62 in (142.8 mm)
  • Power cable: 5.91 ft (1.8 m)
  • Weight - device only: 1.05 lbs (477 g)
  • Weight - with power adapter: 4.58 oz (130 g)
Additional Information
Author
with
Paige Reisman
24,192 Reputation
15 Guides authored
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 155
All Time: 21,602
