Up to 20% off select tools
Google Home Sound Driver Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
97
All Time:
3,362
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Fix your Google Home's poor audio quality with a new sound driver.
This guide will teach you how to take apart your Google Home to remove a faulty sound driver and replace it with a new one.
    1. Google Home Sound Driver Replacement, Interconnect Cable: step 1, image 1 of 3 Google Home Sound Driver Replacement, Interconnect Cable: step 1, image 2 of 3 Google Home Sound Driver Replacement, Interconnect Cable: step 1, image 3 of 3
      • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
      • Pull off the Google Home’s magnetically attached base and set it aside.
      • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
      • After all four screws are out, pop the lid off the device to open the capsule.
      Ask FixBot
    2. Google Home Sound Driver Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Carefully remove the interconnect cable using a pair of tweezers.
      Ask FixBot
    1. Google Home Sound Driver Replacement, Mute Button Switch: step 3, image 1 of 2 Google Home Sound Driver Replacement, Mute Button Switch: step 3, image 2 of 2
      • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
      Ask FixBot
    2. Google Home Sound Driver Replacement: step 4, image 1 of 2 Google Home Sound Driver Replacement: step 4, image 2 of 2
      • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
      • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
      Ask FixBot
    1. Google Home Sound Driver Replacement, Motherboard: step 5, image 1 of 2 Google Home Sound Driver Replacement, Motherboard: step 5, image 2 of 2
      • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
      • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
      Ask FixBot
    2. Google Home Sound Driver Replacement: step 6, image 1 of 2 Google Home Sound Driver Replacement: step 6, image 2 of 2
      • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
      • Remove the motherboard.
      Ask FixBot
    1. Google Home Sound Driver Replacement, Sound Driver: step 7, image 1 of 2 Google Home Sound Driver Replacement, Sound Driver: step 7, image 2 of 2
      • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws on the bottom of the device.
      • For this step you will need a T6 screwdriver with an extra long head to reach the screws.
      Ask FixBot
    2. Google Home Sound Driver Replacement: step 8, image 1 of 2 Google Home Sound Driver Replacement: step 8, image 2 of 2
      • Using a Torx T6 screwdriver head, unscrew the six black 1.7mm Torx screws on the side of the device.
      Ask FixBot
    3. Google Home Sound Driver Replacement: step 9, image 1 of 2 Google Home Sound Driver Replacement: step 9, image 2 of 2
      • Pull apart the black casing to reveal the sound driver.
      • Remove the sound driver.
      Ask FixBot
6 other people completed this guide.
Author
with
Gabe Hyun
847 Reputation
4 Guides authored
Cal Poly, Team S24-G11, Maness Spring 2018 Member of Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Members
60 Guides authored
4 Guide Comments
I have a torn speaker cone. Can these be replaced and where can I buy the parts
rchrdsmmnds - Reply Share
I would like to know where I can buy a replacement speaker for my Google Home. Thanks in advance P.s has anybody else had their speaker blow on them on the Google Home?
Mark Goff - Reply Share
Looking for replacement speaker, where do I find?
Corey Anderson - Reply Share
replacement speaker for google home, someone knows here i find?
model:PLS -50N25AL07-04
or compatible speaker
vinyboylima - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 97
All Time: 3,362
