Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification:
The SN30 Pro+ is a wireless game controller designed by 8BitDo. Released 7 August 2019. Its design is similar to the SN30 Pro, but instead of a dog bone shape, there is the addition of grips to each side. With two joysticks, two analog triggers, and primary D-pad, this controller’s layout is similar to Dualshock. The controllers is compatible with several devices either via Bluetooth or USB-C cable.
The SN30 Pro+ is available is three different editions. Black Edition has a black body and black ABXY buttons. G Classic Edition has a sandstone body and burgundy ABXY. SN Edition has a gray body with lavender buttons.
Software:
8BitDo Ultimate Software
This software allows you to customize button mapping, adjust stick & trigger sensitivity, vibration control and create macros with any button combination. SN 30 Pro+ needs a specific version of the 8BitDo Ultimate Software. It is available on 8BitDo website.
-8BitDo Ultimate Software
Specifications:
Compatibility:
  • Nintendo Switch,
  • Windows,
  • MacOS,
  • Steam,
  • Android
  • Raspberry Pi
Power:
  • Removable 1000mAh Li-on battery
  • USB-C connector (recharge)
  • 20 play hours with 4 hour charging time
Connectivity:
  • Bluetooth 4.0
  • USB-C
Features:
  • Modifiable vibration
  • 6-axis motion controls
  • Adjustable hair triggers
  • Customizable turbo function
Size:
  • 153.6 × 102.7 × 64.3mm
  • 222g
Box Contents:
  • SN30 Pro+ Bluetooth gamepad
  • USB-C cable
  • Instruction manual
Source: 8BitDo SN30 Pro+ Tech Specs
Additional Information:
For additional help in identifying and repairing the device, please reference the following sources:
-8BitDo SN30 Pro+ FAQ
-8BitDo SN30 Pro+ Bluetooth Gamepad Manual
8BitDo SN30 Pro+ Bluetooth Gamepad Instruction Manual (EN, ZH)
8BitDo PS Receiver Instruction Manual
Author
with
Brian W
1,800 Reputation
8 Guides authored
Past 24 Hours: 7
Past 7 Days: 43
Past 30 Days: 198
All Time: 23,252
