Up to 20% off select tools
8BitDo SN30 Pro+ Controller Analog Sticks Replacement
Views: 16K
View statistics:
Past 24 Hours:
18
Past 7 Days:
86
Past 30 Days:
296
All Time:
15,851
Comments: 8
3 comments on steps, 5 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 25 minutes
Difficulty: Difficult
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide is used for the replacement of the Analog Sticks on your 8BitDo SN30 Pro+ controller.
This guide requires desoldering and soldering the motor wires.
    1. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Battery: step 1, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Battery: step 1, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Battery: step 1, image 3 of 3
      • Place the controller face down.
      • Remove the battery cover.
      • Remove rechargeable battery or AA batteries.
      Ask FixBot
    2. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Trigger Buttons: step 2, image 1 of 2 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Trigger Buttons: step 2, image 2 of 2
      • Remove L2 and R2 trigger buttons by pushing them away from the grips.
      Ask FixBot
    3. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: step 3, image 1 of 2 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use Tweezers to uncover two screws under the label in the battery compartment.
      • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
      Ask FixBot
    4. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Unclip Covers: step 4, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Unclip Covers: step 4, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Unclip Covers: step 4, image 3 of 3
      • At the end of each grip, pry apart the covers.
      • Use fingernail or opening pick to undo the two top clips.
      • One clip next to L button.
      • One clip next to R button
      • Undo the final clip between the joysticks.
      Ask FixBot
    5. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Covers: step 5, image 1 of 1
      • Carefully move the rear cover away and from the front cover. Place it to the left.
      • Do not completely separate. The two halves are still attached via a white ribbon cable.
      Ask FixBot
    1. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Ribbon Cable: step 6, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Ribbon Cable: step 6, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Ribbon Cable: step 6, image 3 of 3
      • Unlock the ribbon cable by push open the black plastic tab.
      • The tab will slide about 1.5mm
      • Pull the ribbon cable out of the connector in the direction of the cable.
      Ask FixBot
    2. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Caps: step 7, image 1 of 2 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Caps: step 7, image 2 of 2
      • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
      Ask FixBot
    3. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: step 8, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: step 8, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Remove Screws: step 8, image 3 of 3
      • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
      • Four around the Right stick
      • Four around the Left stick
      • One next to the Battery connector
      Ask FixBot
    4. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Rear Board: step 9, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Rear Board: step 9, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Separate Rear Board: step 9, image 3 of 3
      • Pull the two rumble motors out of their housings.
      • Grab the analog sticks to pull out the circuit board
      Ask FixBot
    1. 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Desolder Analog Sticks: step 10, image 1 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Desolder Analog Sticks: step 10, image 2 of 3 8BitDo SN30 Pro+ Controller Analog Sticks Replacement, Desolder Analog Sticks: step 10, image 3 of 3
      • Flip over the rear board.
      • Using a soldering iron to desolder all the joints of the analog sticks.
      • Make sure all the solder holes are open on the circuit board.
      • Refer to the following solder guide if necessary: How To Solder and Desolder Connections
      Ask FixBot
3 other people completed this guide.
Author
with
Brian W
1,800 Reputation
8 Guides authored
5 Guide Comments
Thanks for the guide! What form factor does the sn30 use for its sticks?
Joshua Randall - Reply Share
Ever figure it out? I'm wondering the same.
Peter Hindes - Reply Share
I asked 8BitDo directly and they sent me this link https://tech.alpsalpine.com/e/products/d...
Stepan Orda - Reply Share
im just trying to replace the worn out joystick wtf
JonnyRoboto - Reply Share
Great guide, thanks! I only needed to get as far as replacing the caps but was useful to know where the hidden screws and clips were ahead of time.
Liam Jackson - Reply Share
Past 24 Hours: 18
Past 7 Days: 86
Past 30 Days: 296
All Time: 15,851
