Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Fails to charge/charging port malfunction
Your device will not come back from the dead.
Faulty charging cable
If you check your cable and see exposed wires, a significant bend, or the cable will not allow the device to charge, then it may be a faulty connection and you will need to purchase a new cord.
Power Source Failure
Test your power source by unplugging your charger and plugging it into another power source to see if it will allow your device to charge. If it charges from another source, then the original source was faulty.
Inefficient Battery
If you plug in your device and it doesn’t turn on or charge within a few minutes, you may need to replace the battery. Please refer to our battery replacement guide.
Faulty Charging Port
Examine your devices charging port, ensure that there are no obstructions in the actual port that are blocking the charging cord from successfully attaching itself into the device. If there is an obstruction, you may need to replace the charging port.
Frozen/broken screen
Your device is unresponsive and your unintentional drop made it even worse.
Low Battery
If your phone will not turn on or the screen is frozen, it may be due to a low battery, which slows the loading speed. Plug the phone into a charging outlet.
Device is unresponsive
If your screen is frozen or will not react when you tap on the screen, try restarting your device by holding down the power button for 5-10 seconds. After it turns off entirely, wait a few seconds, and then hold down the power button again to turn it back on.
Faulty Screen
If your device's screen is still unresponsive and will not turn on or off, the screen may need to be replaced.
Audio output over speaker or headphones malfunction
The device is not producing any sound through the speakers or headphones.
The volume is off
Your device may not be producing sound through the speakers or headphones due to the volume being turned down. Turn up the volume using the top button on the left side of the device.
Faulty headphones
If your headphones aren’t allowing sound to be heard, try using a different headset to see if the problem still occurs. If no sound is heard in your second attempt, your headphones might be broken and need to be replaced.
Faulty speakers
If your device’s speakers aren’t producing sound, you may want to have a look in the settings page of your device to see if the sound is actually on and turned up. If your device is still not producing audio, then the speakers may need to be replaced or disposed of. Please refer to the speaker replacement guide.
Bad audio jack
If your headphones are unable to properly fit into the audio jack, and your device is not projecting sound through your headphones, then your audio jack might be broken and may need to be replaced.
Device is Overheating
If your device randomly shuts off with no notification while being used or feels warm to the touch.
Screen brightness is too high
Your device may be overheating due to your screen brightness being turned up too high. Open your device settings and lower the brightness down through the display settings, especially if you are using the device outside.
Extended filming
In many cases, the camera being overworked could be the reason for your device overheating. This can happen when long videos are being recorded. It is recommended that you take a break from filming and close the camera app.
Unused apps are running
Your device may be overheating from running unused apps while you’re on your device. If you are not currently using an app, get into the habit of closing it. This goes for tabs in your web browser as well. Disabling the location services and push notifications for the apps is recommended as well.
The device is being used while charging
Using your device while charging can cause it to overheat, especially when using high CPU-sucking apps for long durations of time. If you can feel it starting to get warm, it is best to give your device a break and let it charge without usage.
Device overcharged
If your device is frequently overcharged, that may be why it’s overheating. Only keep the device plugged into the charger until it reaches around 80% battery, then unplug it shortly thereafter. The chances of your device overheating are more likely when it is at a full charge. Charging your device to 100% also shortens the battery’s lifespan. However, if you must charge your device overnight, it is recommended that you keep it on a cool, flat surface such as a nightstand, rather than on your bed or pillow.
Power/Volume button is stuck/loose
The power or volume buttons aren’t functioning, or you feel that they are loose or stuck.
Buttons are stuck
If your power or volume buttons don’t move when you push on them, then it may be because they are stuck in your device. Use a tool such as a toothpick or small wedge to pull out the buttons.
Buttons are broken
Your buttons may be broken if they are loose or stuck inwards. If the buttons continue to stick or are loose, the buttons may need to be replaced. Please refer to our volume and power button replacement guide.
Damaged Front-Facing Camera
Your device is not producing those amazing pictures that you so much deserve.
Camera lens is cracked/scratched
If the photos that you are trying to take on your device are blurry it may be because there is a crack/scratch on the front-facing camera. Examine your device and notice if there is a crack or scratch and if there is, you may need to replace the front-facing camera. Please refer to our front-facing camera replacement guide.
Pictures are blank
If the pictures you are taking result in a blank, black picture, you may need to replace the motherboard in your device. Please refer to our motherboard replacement guide.
Damaged Back Camera
If the photos that you are trying to take on your device are blurry it may be because there is a crack/scratch on the back camera. Examine your device and notice if there is a crack or scratch; if there is, then you may need to replace the back camera. Please refer to our back camera replacement guide.
Pictures are blank
Author
with
Maria Stock
524 Reputation
5 Guides authored
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Member of UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Members
84 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 571
