ZTE Prestige 2 Back Camera Replacement
    1. ZTE Prestige 2 Back Camera Replacement, Battery: step 1, image 1 of 3 ZTE Prestige 2 Back Camera Replacement, Battery: step 1, image 2 of 3 ZTE Prestige 2 Back Camera Replacement, Battery: step 1, image 3 of 3
      • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
      Ask FixBot
    2. ZTE Prestige 2 Back Camera Replacement: step 2, image 1 of 2 ZTE Prestige 2 Back Camera Replacement: step 2, image 2 of 2
      • Remove the battery.
      Ask FixBot
    1. ZTE Prestige 2 Back Camera Replacement, Back Panel: step 3, image 1 of 3 ZTE Prestige 2 Back Camera Replacement, Back Panel: step 3, image 2 of 3 ZTE Prestige 2 Back Camera Replacement, Back Panel: step 3, image 3 of 3
      • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
      Ask FixBot
    2. ZTE Prestige 2 Back Camera Replacement: step 4, image 1 of 3 ZTE Prestige 2 Back Camera Replacement: step 4, image 2 of 3 ZTE Prestige 2 Back Camera Replacement: step 4, image 3 of 3
      • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
      • There will be a lot of resistance, apply adequate pressure.
      Ask FixBot
    1. ZTE Prestige 2 Back Camera Replacement, Back Camera: step 5, image 1 of 3 ZTE Prestige 2 Back Camera Replacement, Back Camera: step 5, image 2 of 3 ZTE Prestige 2 Back Camera Replacement, Back Camera: step 5, image 3 of 3
      • Use the iFixit opening pick and wedge it under the press fit connector beside the camera located at the top center of the device to pop it off.
      • Remove the camera.
      • The camera cable near the press fit connector is delicate, ripping it will cause permanent damage.
      • The base of the camera may be glued down which may lead to accidental ripping during removal. Use the flat end of a metal spudger to pry it up if necessary.
      Ask FixBot
Maria Stock
524 Reputation
5 Guides authored
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Member of UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 65
All Time: 605
