Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Smartphone Won’t Turn On
Your smartphone won’t power on or even respond.
Drained Battery
Your battery may be low. Plug in the charger and let your phone charge for at least ten minutes. Try to turn on your phone now.
Dead Battery
Plug in the ZTE to the charger. If the phone doesn’t charge, the battery is probably dead or there is a problem with the charging port. Replace the battery with another charged battery. In case the phone still doesn’t turn on, it might be a problem in the motherboard.
Faulty Motherboard
If you have tried to replace the battery and your phone still doesn't turn on, your motherboard is probably broken. You will need to replace it.
Smartphone Won’t Take Pictures
You can't take pictures with your ZTE.
Back Camera is Blocked
Take a look at the phone's camera. Make sure the camera isn't blocked by the case or your thumbs. If there's something blocking the camera, remove it and try to take pictures again.
Lens is Dirty
If your pictures are blurry, your lens may be dirty. Use a cloth to clean your camera and try to take pictures again to see if the problem is solved.
Back Camera is Damaged
Your camera may be scratched or not working. You will need to replace it.
The Phone Won't Charge
Wall Socket is Broken
Check if the wall socket works, try to charge other devices. If other devices don't charge using the same socket, that means you have a broken socket.
Wrong Charger
Make sure you are using the correct charger and that it is plugged into an outlet that works. After that, try to turn on the phone.
Dead Battery
Plug in the ZTE to the charger. If the phone doesn’t charge, the battery is probably dead or there is a problem with the charging port. Replace the battery with another charged battery. If the new battery works, that means that your old battery is dead.
Can't Make Phone Calls With My ZTE
Replace the SIM Card
Your SIM card may not be working anymore. Check with your phone carrier if you can still use this card. If you don't need the card anymore, you can replace it.
ZTE is Frozen
The screen of your phone is frozen and it doesn’t respond.
Restart the Phone
You will have to turn your phone off. To do that, remove the battery and put it back. Turn on your phone.
Cracked Back Cover
The back of your device is badly damaged or showing wear and you want to replace it with a new one.
Cover Replacement
If your back cover is cracked, you can replace it.
No Sound Coming From The Speaker
There’s no sound coming from your phone.
Volume is Off
If there is no sound coming from your speakers, check that you have your volume unmuted and turned up. Press the button to increase the volume and try to listen to music again.
Headphones are Connected
If there are headphones connected to your ZTE, the sound will not come out of the speakers. Unplug your headphones. Try to listen to music again.
I Can’t Listen to Music with Headphones
Headphones Won’t Connect to the Device.
Loose Headphone Jack
Check if the audio is coming out of the speakers. If you notice audio cuts, the headphone is probably not connected properly. Make sure that your headphone is fully connected to the smartphone.
Broken Headphones
Your headphones might be broken. Try to use different headphones. If you can listen to music using different headphones, then you have a problem with the previous headphones.
Author
with
Jordano Baer
716 Reputation
5 Guides authored
USF Tampa, Team S9-G4, Remmell Fall 2017 Member of USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Members
60 Guides authored
3 Comments
Srceen won't swipe bought new screen still won't swipe come on touch don't
Frank Smith - Reply Share
My phone won't stay on the screen, I'm either looking at our texting on. It jumps to a completely different site every few seconds. Extremely annoying.
Tina Epler - Reply Share
Recently my screen froze, and I let the battery die out, afterwards I tried turning it on and to my surprise my phone have been logged out of my Google account. It said my password had been changed which never happened I signed in with my laptop no problem but my phone will not let me what can I do?
Omar Montez - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 2,399
