ZTE Grand X Max Plus Back Cover Replacement
    1. ZTE Grand X Max Plus Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Make sure you turn off your phone before starting.
      • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
      • You can also use a hair dryer or a heating gun for this step.
      Ask FixBot
    2. ZTE Grand X Max Plus Back Cover Replacement: step 2, image 1 of 2 ZTE Grand X Max Plus Back Cover Replacement: step 2, image 2 of 2
      • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
      • Don't apply too much pressure because the cover can crack easily.
      • To avoid that your cover cracks, you can add tape to back cover.
      • You can use a suction cup to help remove the battery.
      Ask FixBot
    3. ZTE Grand X Max Plus Back Cover Replacement: step 3, image 1 of 2 ZTE Grand X Max Plus Back Cover Replacement: step 3, image 2 of 2
      • Carefully remove the cover from the phone.
      Ask FixBot
2 other people completed this guide.
Jordano Baer
716 Reputation
5 Guides authored
USF Tampa, Team S9-G4, Remmell Fall 2017 Member of USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Members
60 Guides authored
1 Guide Comment
There seems to be an antenna attached to the mid frame that gets stuck to the back glass on the top left. Does anyone know what this is??
Kiki Jade - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 93
All Time: 904
