Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone does not charge when plugged in
The phone's battery does not recharge when connected to a charging cable and power brick.
Faulty Charging Cable
The charging port may break through physical damage or wear over time. If the phone does not charge because the charging cable is broken, swap the Micro-USB charging cable for a different working Micro-USB charging cable.
Faulty Power Brick
The power brick may break through physical damage or wear over time. If the phone does not charge because the power brick is broken, swap the USB power brick for a different working USB power brick.
Faulty Phone Battery
Plug in another device into the charging cable. If the device charges, it is likely that the phone's battery is faulty. Swap the battery using this guide.
Faulty Charging Port
If the phone does not charge after a battery replacement, the charging port is likely broken. If the charging port looks disfigured, it may also be broken. Replace the Micro-USB charging port with this guide.
Unresponsive Touchscreen
The screen does not respond when stimulated by the touch of a finger.
Overheated Phone
When the phone gets too hot, the screen may become unresponsive. If the phone feels too hot, lower the temperature of the phone by placing the phone in a cooler environment.
Software Malfunction
Software errors may be the reason the phone to be unresponsive to touch. Restarting the device will reset the software and the touch screen may work after the phone restarts. To restart the phone, hold the power button for 10 seconds. There should be a vibration as the phone restarts.
Broken Screen
The digitizer underneath the glass LCD display converts touch to signals that are send to the motherboard. A broken digitizer means an unresponsive screen. The screen is composed of the digitizer and LCD display. Often times, when the LCD display cracks, the digiziter breaks as well. Replace the screen using this guide.
No Audio Through Headphones
There is no sound through headphones when the 3.5mm stereo jack of the headphone is plugged into the 3.5mm headphone jack on the phone.
Dirty Headphone Jack
When the headphone jack on the phone is dirty, there can be a poor connection between the headphones and the phone. Take a dry Q-tip and gently clean the headphone jack.
Broken Headphones
The headphones themselves may be broken. Test the headphones on another device to check if they are working.
Broken Headphone Jack Port
The headphone jack port itself on the phone may be broken. Test a working pair of headphones on the phone to ensure the headphone jack is broken. Replace the headphone jack using this guide.
Blurry Camera
The camera takes blurry photos.
Out of Focus
The camera may be out of focus as it is taking the picture. To focus the camera, tap the desired location on the screen to get the camera to focus on that spot.
Poor Lighting
The camera has to be exposed to light for a certain amount of time to take a photo. When there is not enough light, the photo may be blurry. Adjust the lighting of the photo to reduce blurriness.
Dirty Camera Lens
The phone's camera lens may be smudged by dirt or fingerprints and cause blurry pictures. If the lens looks dirty, wipe the camera lens with a microfiber cloth. Do not use any industrial cleaning solutions.
Dust Inside Camera Lens
Dust may enter the camera lens and cause blurry pictures. If wiping the camera lens does not get rid of the dirty, dust may have entered the camera lens. Replace the front camera using this guide. Replace the rear camera using this guide.
Slow/Unresponsive Software
The phone is slow to or does not open applications or respond to touch.
Phone is too Hot
When the phone is too hot, the CPU functions less efficiently, slowing down or making the phone unresponsive. If the phone feels hot, place the phone in a cooler environment to cool down the CPU.
Too Many Applications Running
When there are too many applications open or running in the background at the same time, the phone will slow down. Tap the recent button on the bottom of the phone, indicated by three lines, and swipe away applications to close them.
Too Little Storage Remaining
When the phone has no storage left, it will slow down. To check the storage on the device, follow these steps:
  1. Go into the Settings app
  2. Tap on Storage
  3. It should show how much storage is used and remaining
Delete any unnecessary applications, text messages, or photos to clear up space on the phone.
Incorrect Touch Sensitivity
The touch screen may not be completely unresponsive but may be slightly unresponsive or too responsive. To calibrate the touch screen, follow the following steps.
  1. Dail*** *#*#64663#*#**** in the phone application
  2. Tap touch sensor
  3. Long press the menu button
  4. Tap touch calibration
  5. Follow on screen instructions to calibrate the screen
Software Issue
Over time, the phone's software can be bogged down and have errors. A factory reset often solves the problem. To do so, follow the following steps.
  1. Backup Data
  2. Turn off the phone
  3. Boot the device into recovery mode by holding down the power and volume down buttons
  4. Navigate to wipe data/factory reset using the volume buttons. Use the power button to select
  5. Select yes-delete all user data
  6. Select reboot system now to restart the phone
Author
with
Zongyi Li
1,653 Reputation
3 Guides authored
Cal Poly, Team S22-G4, Livingston Spring 2017 Member of Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Members
96 Guides authored
70 Comments
For the Incorrect Touch Sensitivity, my phone (Redmi note 6 pro) doesn’t have touch sensor option on that page and just have Touchpanel section that haven’t any menu like calibrate the screen…
Ashkan Rahmani - Reply Share
My sim is not working.
goutamchowdhury1964 - Reply Share
My phone sim is not working
3 number problem in my phone note 7 pro kaise thik hoga
FEARLESS LION - Reply Share
My mobile mi note4 some app not open show bug report
narendra shekhawat - Reply Share
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 95
All Time: 52,440
