Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓This guide will show you how to replace your phone's rear-facing camera.
Insert the plastic opening tool between the charging port and the rear case.
Pry the end of the rear case up from the charging port.
Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
Run the plastic opening tool along the seam.
Pry up the midframe with the plastic opening tool.
Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
4 other people completed this guide.
