Up to 20% off select tools
Xiaomi Redmi Note Battery Replacement
Views: 17K
View statistics:
Past 24 Hours:
9
Past 7 Days:
46
Past 30 Days:
256
All Time:
17,377
Comments: 3
3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery in your phone if it is old, damaged, or losing its charge too quickly. The replacement process is simple and only requires three steps.
    1. Xiaomi Redmi Note Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
      • Insert the plastic opening tool between the charging port and the rear case.
      • Pry the end of the rear case up from the charging port.
      Ask FixBot
    2. Xiaomi Redmi Note Battery Replacement: step 2, image 1 of 2 Xiaomi Redmi Note Battery Replacement: step 2, image 2 of 2
      • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
      Ask FixBot
    3. Xiaomi Redmi Note Battery Replacement: step 3, image 1 of 2 Xiaomi Redmi Note Battery Replacement: step 3, image 2 of 2
      • Locate the indentation at the bottom of the battery.
      • Place a finger in the indentation and lift up to remove the battery.
      Ask FixBot
6 other people completed this guide.
Author
with
Slater Stewart
282 Reputation
1 Guide authored
Cal Poly, Team S22-G4, Livingston Spring 2017 Member of Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Members
96 Guides authored
3 Guide Comments
Geht das so einfach auch bei Redmi note 7 ???
Ingeborg Langer - Reply Share
Ich fürchte nein, sie ist als “nicht entfernbar" beschrieben.
VauWeh - Reply Share
Wie sieht es beim Redmi Note 11 S aus?
Schlotti P. - Reply Share
Past 24 Hours: 9
Past 7 Days: 46
Past 30 Days: 256
All Time: 17,377
