Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet Won't Power On
Tablet will not respond and power button will not cause the device to turn on.
Battery is Dead
Use the charger provided with the Xiaomi Mi Pad to plug the tablet in to the wall or a computer and allow it to charge for a few hours.
Battery is Defective
If your tablet will not charge and you have ensured that it is in fact defective and the problem isn't the charger, the battery will need to be replaced. If your tablet is still under warranty from the manufacturer then you can contact them for a replacement.
Charger is Defective
Ensure the problem is the charger itself by testing the same cord with another device and also test the charger in a different outlet. If the charger is still not working then it is broken and should be replaced. Any Micro USB charger will work with this device.
Motherboard is Defective
The motherboard needs to be replaced if the tablet has a full charge but won't power on.
Screen Doesn't Function Correctly
Screen is black or won't display the image properly
Tablet Needs to be Charged
If your screen isn't working properly, make sure the device is on and charged before trying anything else.
Tablet Needs to be Restarted
Often times electronics simply need to be reset when they aren't functioning properly. Power off your device and allow it to sit for 30 seconds before powering it back on.
Tablet Needs to be Factory Reset
If a simple restart was not enough to fix the screen then it may require a reset.
Note: Be careful to back up any important files or pictures before performing a factory reset as you will lose the data on your device.
  1. First turn off the tablet.
  2. Press and hold the "Volume Down" button and the "Power Button" together.
  3. The tablet should now be in recovery mode and displaying a menu.
  4. Use volume down to select wipe data / factory reset.
  5. Use volume up to confirm.
  6. Wait for the tablet to completely wipe itself before doing anything further.
  7. The reboot system will confirm that the wipe was successful.
  8. Wait until the tablet is fully powered on to see if the problem is fixed.
Screen Needs to be Replaced
If none of the above solutions were successful in fixing the screen on your tablet, the screen is damaged and needs to be replaced.
Tablet Won't Produce Sound
The tablet won't play audio from music or videos.
Headphones Not Plugged In
Ensure the headphones are fully plugged in and check that they are functional on other devices.
Volume Is Low or Muted
Make sure that the volume is not off or muted with the volume up button on the right side of the tablet.
Defective Headphone Jack
Headphone jack is defective and needs to be replaced.
Camera Doesn't Function Properly
Camera screen is black or won't display a picture
Tablet Requires a Restart
In order to get the camera working, your Mi Pad should be restarted to reset the functionality of the camera.
Camera Lens is Blocked or Broken
Check the camera lens on the back of the device to make sure the camera lens is neither obstructed nor broken. If the lens is broken it will need to be replaced.
Camera Requires Replacement
If the camera doesn't appear to be broken but will still not function, it will need to be replaced.
Identify if the front camera or back camera needs to be replaced.
Forgotten Passcode
You forgot the password for your Xaiomi Mi Pad
If you cannot remember the passcode to the device then a factory reset will need to be performed.
Kiefer Sivitz
572 Reputation
3 Guides authored
USF Tampa, Team 12-5, Blackwell Fall 2015 Member of USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Members
72 Guides authored
18 Comments
Hie guys ...my mi pad 2 ..jus shuts down on it on ...it takes time to reboot after several times of trying..please help
Danny - Reply Share
Please help, I cannot factory reset and I forgot my password
Planetearthissues - Reply Share
I am not getting any option for factory reset after pressing the volume down key and power button. It just turn on the device.
Rahul Singh - Reply Share
hello guyz, mi pad showing 98% charging and its not discharging...what will be the issue?
pratham966 - Reply Share
Guys ,Press volume up button and power key together
chandra mouli - Reply Share
Past 24 Hours: 3
Past 7 Days: 44
Past 30 Days: 163
All Time: 51,869
