Xiaomi Mi Pad Front Camera Replacement
    1. Xiaomi Mi Pad Front Camera  Replacement, Rear Case Assembly: step 1, image 1 of 1
      • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
      Ask FixBot
    2. Xiaomi Mi Pad Front Camera  Replacement: step 2, image 1 of 2 Xiaomi Mi Pad Front Camera  Replacement: step 2, image 2 of 2
      • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
      • The back panel has small clips and light adhesive that easily releases from the device.
      Ask FixBot
    1. Xiaomi Mi Pad Front Camera  Replacement, Front Camera: step 3, image 1 of 2 Xiaomi Mi Pad Front Camera  Replacement, Front Camera: step 3, image 2 of 2
      • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
      Ask FixBot
    2. Xiaomi Mi Pad Front Camera  Replacement: step 4, image 1 of 1
      • Remove the upper cover from the device.
      Ask FixBot
    3. Xiaomi Mi Pad Front Camera  Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to gently disconnect the front-facing camera from the motherboard.
      Ask FixBot
    4. Xiaomi Mi Pad Front Camera  Replacement: step 6, image 1 of 1
      • Carefully remove the front camera from the device.
      Ask FixBot
Rene Mendoza
323 Reputation
2 Guides authored
USF Tampa, Team 12-5, Blackwell Fall 2015 Member of USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 96
All Time: 1,620
