Xiaomi Mi Pad Battery Replacement
Views: 30K
View statistics:
Past 24 Hours:
6
Past 7 Days:
76
Past 30 Days:
329
All Time:
30,435
Comments: 12
12 guide comments.
Go to guide comments
Completed: 19
19 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Use this guide to remove the battery from your Xiaomi Mi Pad.
Tools
    1. Xiaomi Mi Pad Battery Replacement, Rear Case Assembly: step 1, image 1 of 1
      • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
      Ask FixBot
    2. Xiaomi Mi Pad Battery Replacement: step 2, image 1 of 2 Xiaomi Mi Pad Battery Replacement: step 2, image 2 of 2
      • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
      • The back panel has small clips and light adhesive that easily releases from the device.
      Ask FixBot
    1. Xiaomi Mi Pad Battery Replacement, Battery: step 3, image 1 of 2 Xiaomi Mi Pad Battery Replacement, Battery: step 3, image 2 of 2
      • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
      Ask FixBot
    2. Xiaomi Mi Pad Battery Replacement: step 4, image 1 of 1
      • Remove the upper cover from the device.
      Ask FixBot
    3. Xiaomi Mi Pad Battery Replacement: step 5, image 1 of 2 Xiaomi Mi Pad Battery Replacement: step 5, image 2 of 2
      • Use a plastic opening tool to disconnect the three ribbon cable connectors.
      • If you're only going to replace the battery, you should only need to disconnect the smallest ribbon cable that connects the battery to the motherboard.
      Ask FixBot
    4. Xiaomi Mi Pad Battery Replacement: step 6, image 1 of 1
      • Carefully pry around the perimeter of the battery with a plastic opening tool to loosen the adhesive securing the battery to the device.
      • Be gentle when removing the battery, as lithium-ion batteries should not be bent or punctured.
      Ask FixBot
    5. Xiaomi Mi Pad Battery Replacement: step 7, image 1 of 3 Xiaomi Mi Pad Battery Replacement: step 7, image 2 of 3 Xiaomi Mi Pad Battery Replacement: step 7, image 3 of 3
      • If you disconnected all three connectors, the charging port ribbon cable may have a small amount of adhesive securing it to the battery. Gently pry the cable free of the battery and lift the battery up and out of the device.
      Ask FixBot
19 other people completed this guide.
Jessica
746 Reputation
1 Guide authored
USF Tampa, Team 12-5, Blackwell Fall 2015 Member of USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Members
72 Guides authored
12 Guide Comments
Hi
Great Tutorial, but where can i buy a replacement Battery?
THANKS
Marcel - Reply Share
Go to Leamington road and you will get it
affan - Reply Share
Go to Leamington road mumbai
affan - Reply Share
Where to purchase the Mi Paf battery?
Dino Bay - Reply Share
Please please make a video for it. I need it desperately.
Man Mohan Shukla - Reply Share
Past 24 Hours: 6
Past 7 Days: 76
Past 30 Days: 329
All Time: 30,435
