Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Ball Won't Turn On
There isn't a response when I press something on the ball.
Batteries Are Dead
First, check if the batteries are put in facing the right way. If they are put in correctly and the ball will not turn on, try fresh batteries. This device runs on 3-AA batteries.
Bad Power Switch
If the batteries are new and put in correctly, check the switch to see if it slides easily. If you can’t physically move it something may be jammed between the switch peg and the outer shell of the ball. If there is nothing on the outside blocking the switch, the solution to this is to open the device to see if there is anything blocking the switch from the inside. If nothing is physically inhibiting the power switch then the next step would be to replace the switch.
Song Skips or Does Not Play
When I press a button, there is no music even though it moves, or the music skips like a scratched CD.
Sound Switch Off
First check the sound switch to make sure the yellow switch is above either the low or high sound setting, this also turns on the device.
Bad Speaker
If all of other functions work, but there isn't any sound, first check the wires that connect the speaker to the circuit board. If they are connected to both the speaker and the circuit board then the speaker may need to be replaced.
Ball has reduced or zero movement
It doesn't roll very much, or at all.
Rolling Surface
Try using the device on a hard flat level surface such as a wooden or tile floor. Thick carpet could prevent the ball from moving to its full potential.
Moving Weight Failure
If the problem persists and the ball doesn't seem to roll as it once did, the weight inside causing it to move may be jammed or its motor may need to be replaced.
Lights Do Not Display
One of the lights doesn’t light up anymore.
Light Bulb Is Dead
The LED bulbs within the device may need to be replaced or have fallen out of place.
Unresponsive Buttons
When I push a button there is no response.
Physical Button Resistance
Try pushing the the buttons to feel if it is hard to push. If it is, open the item and look to see if there is something inside keeping the button from being pushed down.
Button Disconnection
The connection within the device from the button to the circuit board may have been disconnected or fried. You should replace the buttons.
Nicholas Kugler
4 Reputation
0 Guides authored
USF Tampa, Team 2-1, Sullivan Fall 2015 Member of USF Tampa, Team 2-1, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G1
4 Members
60 Guides authored
3 Comments
How do I switch from the Spanish mode to the English mode?
Albert - Reply Share
Mine is stuck like a broken record. It starts okay, but then makes this most annoying sound over and over and over again.
elinor17 - Reply Share
Black wire came away from battery compartment cant fimf where both ends connect
Benny O connor - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 39
All Time: 5,083
