Vtech Move and Crawl Ball Battery Replacement
Views: 5.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
102
All Time:
5,646
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
The main troubleshooting solution is to remove then reinstall the batteries, or replace dead batteries. This is also the first step in any other replacement for this toy.
Parts
Tools
    1. Vtech Move and Crawl Ball Battery Replacement, Battery: step 1, image 1 of 2 Vtech Move and Crawl Ball Battery Replacement, Battery: step 1, image 2 of 2
      • There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
      Ask FixBot
    2. Vtech Move and Crawl Ball Battery Replacement: step 2, image 1 of 3 Vtech Move and Crawl Ball Battery Replacement: step 2, image 2 of 3 Vtech Move and Crawl Ball Battery Replacement: step 2, image 3 of 3
      • Pry the batteries out with your finger. When you replace them be sure to orient them correctly according to the markings in the slots. Match the plus symbol on the battery to the plus symbol in the slot.
      Ask FixBot
Taylor Smith
240 Reputation
2 Guides authored
USF Tampa, Team 2-1, Sullivan Fall 2015 Member of USF Tampa, Team 2-1, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 102
All Time: 5,646
