Player keeps freezing
When using your player, it is unresponsive.
Reset the player
Try removing the battery from the player and then reinserting it. This resets the player and may resolve this issue.
Perform a clean up
You may need to perform a clean up on your device. Performing a clean up will remove any invalid links from your music library. Don't worry, this will have no effect on your other music files. To do this, click here.
Player keeps disconnecting from computer
The device doesn't stay connected when you plug it into your computer.
Player is incorrectly connected
Be sure that the player is correctly connected to the computer by the USB cable and that there are no loose connections.
Broken/bad USB cable
You may have a no longer functioning USB cable. If available, try connecting your player to a different USB cable.
Bad computer
It is possible that the issue is your computer and not the player. Try to connect to a different computer to test if the player will stay connected.
Poor radio reception
When listening to the radio, the signal is too weak so you hear static.
Too short of a wire
This weak signal strength is related to low radio frequencies. To overcome this low frequency, try using a longer wired earphone. Using a longer wired earphone will allow the cable to act like an antenna for the FM reception. When using this longer wired earphone, make sure that it is running in full length and not coiled up.
Player won't go loud enough
Even with the player at maximum volume level, the player isn't loud enough.
Enable volume restrictions
Each player comes with the ability to enable or disable the volume restrictions in order to prevent the player from reaching too loud of a level. To check if your player has this setting, go to the main menu and select System, Audio settings, Restrict volume. You will then be asked to set a password and once inputted, a volume bar will appear. You can now increase your volume to the desired level and then select OK to enable this volume restriction.
Battery charge problems
Your player is not loading properly and is running slower than usual.
Low battery life
If your player's battery life is at its minimum, your player will not load properly. The easiest way to solve this issue is to charge your player with its AC power adapter or USB port without turning on the player. Leave connected for the next 60 minutes until the screen lights up.
Bad/dead battery
Your battery might not be working anymore. To replace your battery, follow the link below:
Click here for instructions
Player screen is white/black
Your display screen on your player is completely white or black and you cannot navigate on your player.
Reset the player
Reset your player to confirm that the screen is functional and able to display its content. To reset your player, first turn it off and remove the battery. Wait for about 5 seconds before re-inserting the battery and turning your player back on. If your display screen remains white/black, read on...
Drained battery
It could also be because your battery is about to die. Plug in your player and allow it to fully charge before checking your screen again.
Firmware is not up to date
Updating the player's firmware is also very essential and can be done by following the link below:
Broken screen
If your screen is still completely white or black, you may need to replace your screen. To do this, follow the link below for instructions below.
Replacing your LCD screen
Author
with
Kelsey
3 Reputation
0 Guides authored
Cal Poly, Team 17-2, Regan Spring 2013 Member of Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Members
96 Guides authored
1 Comment
The Creative webpage only has manuals for this device. Please update this page, unless you have another source for the firmware.
Jaymz See (Nonkatt) - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 4,216
