Up to 20% off select tools
Creative Zen Vision W Battery Replacement
Views: 7.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
34
Past 30 Days:
168
All Time:
7,791
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
The Creative Zen Vision W was a very popular media player before they were discontinued. Since the media player is pretty old, its batteries may not be able to keep up anymore and may die as well. However, it may be slightly difficult to take the old battery out of the player itself, so that's where this guide comes in. This guide allows you to remove the older battery for replacement in the Creative Zen Vision W. Make sure to follow the step-by-step instructions carefully.
    1. Creative Zen Vision W Battery Replacement, Battery Removal: step 1, image 1 of 3 Creative Zen Vision W Battery Replacement, Battery Removal: step 1, image 2 of 3 Creative Zen Vision W Battery Replacement, Battery Removal: step 1, image 3 of 3
      • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
      Ask FixBot
    1. Creative Zen Vision W Battery Replacement, Battery: step 2, image 1 of 2 Creative Zen Vision W Battery Replacement, Battery: step 2, image 2 of 2
      • Remove the three 4 mm exposed screws using a Phillips #0 screwdriver.
      • Peel off the the sticker that says "Creative Warranty Void if broken" and remove the 4 mm screw beneath with a Phillips #0 screwdriver.
      Ask FixBot
    2. Creative Zen Vision W Battery Replacement: step 3, image 1 of 3 Creative Zen Vision W Battery Replacement: step 3, image 2 of 3 Creative Zen Vision W Battery Replacement: step 3, image 3 of 3
      • Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
      Ask FixBot
Follow these instructions in reverse order to reassemble your device.
2 other people completed this guide.
Author
with
Tim Wilson
143 Reputation
6 Guides authored
Cal Poly, Team 17-2, Regan Spring 2013 Member of Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Members
96 Guides authored
3 Guide Comments
Where can I buy the battery, does not seem to be available on ebay or amazon
Mafaz - Reply Share
where can i buy this exact battery. Can't find it with 6 tabs, only 4.
Bernie - Reply Share
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
Matt Wyckoff - Reply Share
Past 24 Hours: 5
Past 7 Days: 34
Past 30 Days: 168
All Time: 7,791
