Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
None of the buttons work
The buttons aren't responsive
The DVD player isn't plugged into a power source
Make sure the DVD player is plugged into a power source and into the TV. Then check to see if the DVD player is turned on by pressing the power button. The power button will turn blue and words will appear on the DVD player’s display.
The wires are plugged into the wrong ports
Check to see that the power cord is plugged into the back of the DVD player, where it indicates "AC IN~". The HDMI cord should be plugged into the TV. If you aren't using an HDMI cord, make sure the AV cables match the colors of the ports they're plugged into.
The wires are damaged
Check to see if any of the wires connected to the DVD player are damaged. If they are, you will need to buy replacement wires.
Jammed power button
The DVD player’s power button is not working
The power button is stuck
When you press the button, make sure that it can be pressed in. It should pop back out when released. If the button is stuck in place, then click here for the guide on how to replace the power button.
DVD player doesn’t read the DVD
The DVD player is unable to read the disc
The DVD is dirty and/or scratched
Check to make sure the DVD is clean and free of scratches. Wipe off any smudges and dust with a soft cloth. Then, check to see if there are any scratches. Scratches prevent the DVD from being read correctly and cannot be used.
The optical lens is faulty
If there appears to be no issues with the DVD, the optical lens may be faulty and will need to be replaced. The optical lens is a bulb which reads the DVD. Click here for the guide on how to replace the optical lens.
The disc tray won’t slide out
The disc tray is unable to open and close
The open button is blocked by debris
Check to see if there is dust or dirt in the crevasses around the button. If there is, use pressurized air or a toothpick to clear the debris.
The drive belt is broken
If the open button is properly working, then the issue could be a faulty drive belt. The drive belt looks like a rubber band, and is what moves the disc tray. Click here for the guide on how to replace the drive belt.
The DVD player is overheating
The surface of the DVD player feels hot
The fan is covered in dust
Check the back of the DVD player for the fan, which will be covered in circular vents. Look to see if there is dust blocking the vents. You can use pressurized air to blow the dust away or a soft cloth or cotton swab to wipe away the dust. If this still doesn’t work, there may be dust inside the fan. Click here for instructions on how to open the DVD player. Click here for furher instructions on how to take out the fan.
The fan isn’t working
Look and listen to see if the fan is spinning. If the fan isn’t spinning, it can cause the DVD player to overheat and cause damage to the circuits and other components of the DVD player. Click here for the guide to replace the fan.
The DVD player has been on for a long time
Like with any electronic, prolonged use will cause the device to overheat. If you have been using the DVD player for more than several hours, power it off and let it cool down for at least 30 minutes.
Nouriyah Saleh
800 Reputation
6 Guides authored
UC Davis, Team S11-G1, Lore Fall 2018 Member of UC Davis, Team S11-G1, Lore Fall 2018
UCD-LORE-F18S11G1
3 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 1,222
